Understanding the Apparent Depth Equation: Explained and Simplified
In summary, the equation d'=d(n2/n1) is derived from Snell's Law, which explains the relationship between the angles of incidence and refraction when light travels through different mediums. The equation represents the apparent depth of an object, d', in terms of its actual depth, d, and the indices of refraction of the two mediums through which light travels.
aeri
Hi, can someone please explain to me where this equation derives from and how it works?
d'=d(n2/n1)
where d'=the apparent depth of the object, d=the actual depth, n1= the index of refraction of the medium in which the refracted light travels, and n1= the index of refraction of the medium in which the incident light travels
d'=d(n2/n1)
Welcome to the PF.
Have you learned about Snell's Law yet? :smile:
https://en.wikipedia.org/wiki/Snell's_law
aeri said:
Yes:)
Great! Then you should be able to make a first attempt at deriving that depth equation. Start with the first figure at the wikipedia link, and change it to be an observer looking down at an object under water...
Something like this? Where P is where the observer is and I is the image of where the object appears to be
Likes berkeman
FAQ: Understanding the Apparent Depth Equation: Explained and Simplified
What is the apparent depth equation?
The apparent depth equation is a formula used to calculate the apparent depth of an object when viewed through a different medium, such as water or glass. It takes into account the refractive index of the medium and the actual depth of the object.
How does the apparent depth equation work?
The equation works by taking the ratio of the refractive index of the medium and the refractive index of air, and multiplying it by the actual depth of the object.
Why is understanding the apparent depth equation important?
Understanding the apparent depth equation is important because it helps us to accurately calculate the depth of objects when viewed through different mediums. This is particularly useful in fields such as optics, physics, and engineering.
Can the apparent depth equation be applied to any medium?
Yes, the equation can be applied to any medium, as long as the refractive index of the medium is known. This includes solids, liquids, and gases.
Are there any limitations to the apparent depth equation?
The apparent depth equation is based on the assumption that the medium is uniform and flat. It may not provide accurate results for objects viewed through curved or non-uniform mediums. Additionally, it does not take into account factors such as surface tension or turbulence, which can affect the apparent depth of an object.
