Apparent magnitude of the Moon from Mercury?
In summary, when Moon is 0.52 AU from Mercury and Mercury sees Moon fully, Moon's apparent magnitude is -12.6. To find Moon's absolute magnitude, use the equation: M=-12.6. To solve for Moon's distance from Earth in AU, use the equation: Ln*dm2=Lm*dn2. To find Moon's distance from Mercury in AU, use the equation: M=2.5log(d).
rtfirefly
I know there there has to be a simple answer to this, but I can't understand where it's at. Here is the question.
Find the apparent magnitude of the Moon [Earth's] as seen from Mercury. Assume Mercury is 0.52 AU from the Moon and that Mercury sees the Moon fully [it's a full moon].
Okay, here is where my thinking lays. I'm going to be using M = m + 5 - 5log(d), where M = absolute magnitude of the Moon, m = apparent magnitude of Moon, and d = distance from Moon to Mercury in parsecs = 2.521×10^(-5) pc.
But the problem I run into is M - I don't know it. I know that the absolute magnitude is the apparent magnitude measured at 10pc, but then I run into not knowing m. I guess I could use the apparent magnitude from Earth (≈-12.6), but when I plug that into the equation using the 10pc I get back -12.6 for the absolute magnitude and that does not work for me. I can only presume I am missing a piece of the puzzle and I don't know where it is. Any help you can offer me would be appreciated.
Astronomy news on Phys.org
Simplify it: skip the 10 pc.
The piece of puzzle which you have not mentioned is the distance of Moon from Earth. Since the distance of Mercury from Moon is conveniently in AU, which is of convenient magnitude, find out distance of full Moon from Earth in AU.
Then ratio of distances Moon-Earth and Moon-Mercury. Which you can then get logaritm from.
Right, thank you, but I was only given this one ready assignment that sort of talks about this stuff and the homework is based on it and did not read anything about this. The closest that it talks about ratios is be using the equation: m -n = 2.5log(Ln/Ln), where m and n are two apparent magnitudes, and Ln and Lm are their brightness. So I really don't know what equation I should be using to solve this problem. I realize that I may have to think outside the text (though in my experience teachers don't like you coming up with stuff from other places), but I did anyways and I still am confused as too what I am suppose to do. I think I'm thinking to hard now and everything at this point is becoming muddled.
You have (Ln/Ln) in your equation - no Lm, and twice Ln, so that expression is always 1.
Just consider that the apparent luminosity decreases with inverse square of distance - for the same source like full Moon and viewed from the same direction,
Lm*dm2=Ln*dn2,
where dm is the distance where object has brightness Lm, and dn is distance where the object has brightness Ln.
Divide that expression with
Ln*dm2
and we get
(Lm/Ln)=dn2/dm2
Now take the logarithm
log (Lm/Ln)=log((dn/dm)2)=2log(dn/dm)
so
2,5 log(Lm/Ln)=5log(dn/dm)
Can you continue from that point?
I can understand your confusion and appreciate your efforts to solve this problem. The apparent magnitude of an object is a measure of its brightness as seen from a specific point of observation. In this case, we are trying to determine the apparent magnitude of the Moon as seen from Mercury, which is 0.52 AU away from the Moon.
To calculate the apparent magnitude, we need to know the absolute magnitude of the Moon, which is defined as the apparent magnitude of an object if it were located at a standard distance of 10 parsecs (32.6 light years). However, this value is not known for the Moon, as it is not a star and does not have a standard brightness.
In this case, we can use the apparent magnitude of the Moon as seen from Earth, which is approximately -12.6. We can then use the distance between Earth and Mercury (0.52 AU) to calculate the apparent magnitude of the Moon as seen from Mercury.
Using the formula you provided, M = m + 5 - 5log(d), we can calculate the apparent magnitude of the Moon from Mercury as:
m = M - 5 + 5log(d) = -12.6 - 5 + 5log(0.52 AU) = -12.6 - 5 + 5(-0.28) = -12.6 - 5 - 1.4 = -19
Therefore, the apparent magnitude of the Moon as seen from Mercury would be approximately -19. This means that the Moon would appear much dimmer from Mercury compared to how it appears from Earth (which has an apparent magnitude of -12.6).
I hope this explanation helps to clarify your confusion. As a scientist, it is important to have a clear understanding of the concepts and equations we use to solve problems. If you have any further questions or concerns, please do not hesitate to ask.
Related to Apparent magnitude of the Moon from Mercury?
1. What is the apparent magnitude of the Moon when viewed from Mercury?
The apparent magnitude of the Moon when viewed from Mercury varies depending on the distance between the two bodies, but on average it has an apparent magnitude of -2.0, making it one of the brightest objects in the Mercurian sky.
2. Why does the apparent magnitude of the Moon change when viewed from Mercury?
The apparent magnitude of the Moon changes when viewed from Mercury because the distance between the two bodies varies based on their positions in their respective orbits. This changes the amount of light that reaches Mercury from the Moon, thus affecting its apparent brightness.
3. How does the apparent magnitude of the Moon from Mercury compare to its apparent magnitude from Earth?
The apparent magnitude of the Moon when viewed from Earth is -12.74, making it significantly brighter than when viewed from Mercury. This is because Earth is much closer to the Moon than Mercury and therefore receives more light from it.
4. Can the apparent magnitude of the Moon from Mercury ever reach 0 or negative values?
No, the apparent magnitude of the Moon from Mercury will never reach 0 or negative values. The apparent magnitude scale is logarithmic, meaning each increase of 1 represents a decrease in brightness by a factor of 2. For the Moon to have an apparent magnitude of 0 or lower, it would have to be over 100 times brighter than it currently is, which is not possible.
5. How does the apparent magnitude of the Moon from Mercury affect its visibility?
The apparent magnitude of the Moon from Mercury plays a role in its visibility, but it is not the only factor. Other factors such as the Moon's phase, Mercury's position in its orbit, and atmospheric conditions on Mercury can also affect its visibility. Generally, the Moon is easily visible from Mercury due to its relatively bright apparent magnitude.
  • Astronomy and Astrophysics
