Apparent vanishing of (magnetic) potential energy
In summary, the metallurgic treatment of an iron material in a magnetic field results in the release of thermal energy, which is then used to demagnetize the material.
stockzahn
137
Dear all,
I cannot figure out my mistake with this thought experiment:
Consider a ferromagnetic material (e.g.iron) in a magnetic field - or just any iron anywhere, since the range of magnetic fields is infinite. Between the ferromagnetic material and (permanent) magnets potential energy is stored. By heating and/or a metallurgic treatment, the iron is transformed into an austenitic steel and therefore loosing its ferromagnetic properties. What happened to the potential energy - it seems to have vanished?
Does the metallurgic treatment require more energy for the rearrangement of the molecule lattice if performed in a strong magnetic field? If this is the case, what happens with this additional energy, if the magnet is removed during the steel is austenitic and then becomes ferritic again (e.g. by cooling down)?
Unfortunately I couldn't find an explanation in the web nor in my books.
Thanks in advance,
stockzahn
There is an exchange between magnetic and thermal energy. A magnetised ferromagnetic material has a minimum potential energy arrangement of its spins relative to the magnetic field. If it goes through a transition to a paramagnetic state, it goes to a state of higher potential energy but also higher entropy. To do this requires energy, e.g. by heating it through the Curie temperature. (Note that potential energy increases; you seem to imply that it decreases.)
This is the basis of the technique of adiabatic demagnetisation for attaining ultra-low temperatures. A sample is magnetised under isothermal conditions - the heat released by going to the low-energy state is conducted away. Then it is allowed to demagnetise under adiabatic conditions - the energy required to go to the higher energy state comes from the thermal energy of the sample - its temperature drops. Repeat and repeat.
Likes Paul Colby, stockzahn and DrClaude
Thanks for the fast response - "magnetic refrigeration" seems to be the "keyword" to find information.
stockzahn
Related to Apparent vanishing of (magnetic) potential energy
1. What is the "apparent vanishing of (magnetic) potential energy"?
The "apparent vanishing of (magnetic) potential energy" refers to the phenomenon where the magnetic potential energy of a system appears to disappear or become unaccounted for. This can occur when there is a change in the magnetic field or when there is a conversion of magnetic potential energy into other forms of energy, such as kinetic energy.
2. How does the apparent vanishing of (magnetic) potential energy occur?
The apparent vanishing of (magnetic) potential energy can occur due to several factors. One common reason is when there is a change in the magnetic field, such as when two magnets are brought closer together or when the direction of the magnetic field changes. Another reason is when there is a conversion of magnetic potential energy into other forms of energy, such as when a magnet moves through a coil of wire and induces an electric current.
3. Is the apparent vanishing of (magnetic) potential energy a violation of the law of conservation of energy?
No, the apparent vanishing of (magnetic) potential energy does not violate the law of conservation of energy. Energy cannot be created or destroyed, only converted from one form to another. In the case of the apparent vanishing of (magnetic) potential energy, the energy is being converted into other forms, such as kinetic energy or electric energy.
4. How is the apparent vanishing of (magnetic) potential energy calculated?
The apparent vanishing of (magnetic) potential energy can be calculated by considering the change in the magnetic field and the resulting change in the potential energy of the system. This can be calculated using equations such as the magnetic potential energy equation or the energy conversion equation for magnetic fields.
5. What are the practical applications of understanding the apparent vanishing of (magnetic) potential energy?
Understanding the apparent vanishing of (magnetic) potential energy is important in many practical applications, such as in the design of magnetic systems and devices. It can also help in understanding the behavior of magnetic fields and their interactions with other forms of energy. Additionally, it is crucial in the development of renewable energy technologies, such as generators and motors, which rely on the conversion of magnetic potential energy into other forms of energy.
  • Classical Physics
  • Classical Physics
  • Electromagnetism
  • Electromagnetism
14K
  • Electromagnetism
