Apparent weight of a submerged rock.
In summary, we have discussed the apparent weight of a rock submerged in water based on its weight and volume. We have also explored how this concept applies to a rock submerged in a liquid with a density twice that of water. The net force downwards, or the apparent weight, is found by subtracting the buoyancy force from the force of gravity.
benjamin8462
What is the apparent weight of a rock submerged in water if the rock weighs 58 N in air and has a volume of 1.8 * 10^-3 m^3?
And then as a continuation:
A rock weighing 57 N with a volume of 2.3 10-3 m3 is submerged in a liquid with a density exactly twice that of water, what will be its new apparent weight reading in the liquid?
I did m*(a+g) but that was incorrect unfortuneately.
When the rock is submerged completely then there will be the force of buoyancy. This force is equal to the weight of the displaced fluid. If all the rock is submerged then the force of buoyancy will be [itex]\rho_{water}Vg[/itex] where [itex]\rho_{water}[/itex] is the density of the water and V is the volume of the rock. So there will be force of gravity ,mg, downwards and the buoyancy force upwards. So the net force downwards is the apparent weight.
[tex]\mbox{Apparent Weight}\quad =mg- \rho_{water}Vg[/tex]
Likes 1 person
FAQ: Apparent weight of a submerged rock.
What is the apparent weight of a submerged rock?
The apparent weight of a submerged rock is the weight of the rock when it is submerged in a fluid, taking into account the buoyant force exerted on the rock by the fluid.
How is the apparent weight of a submerged rock calculated?
The apparent weight of a submerged rock is calculated by subtracting the buoyant force from the actual weight of the rock. The buoyant force is equal to the weight of the fluid that the rock displaces.
What factors affect the apparent weight of a submerged rock?
The apparent weight of a submerged rock is affected by the density of the fluid, the volume of the rock, and the acceleration due to gravity.
Why does a submerged rock feel lighter than its actual weight?
A submerged rock feels lighter than its actual weight because it is experiencing an upward force, the buoyant force, from the fluid it is submerged in. This buoyant force counteracts the weight of the rock, making it feel lighter.
How does the apparent weight of a submerged rock change if it is submerged in a denser or less dense fluid?
If a rock is submerged in a denser fluid, the buoyant force will be greater, causing the apparent weight of the rock to decrease. If a rock is submerged in a less dense fluid, the buoyant force will be less, causing the apparent weight of the rock to increase.
