Apparently easy but super frustrating question about Boyle's Law
In summary, the conversation discusses the application of Boyle's Law to different gases, with the main question being how to compare two different ideal gases. The book states that Boyle's Law and Avagdro's Law imply that p/n is the same for all ideal gases, but the speaker is struggling to understand why this is true and asks for a proof. The conversation also brings up the assumptions of kinetic theory of gases and the characteristics of ideal gases.
darussiaman
Okay... everywhere i look, it keeps talking about Boyle's Law applied to THE SAME gas! It's so frustrating and retarded! I get it, p1V1 = p2V2. Yay... I didn't even need to look THAT up!
But my question is, how do you compare 2 different (ideal) gases?? It seems like such an obvious problem to address, but google searching just yields pages and pages of what I said above, rather than addressing this... Grr. Anyway, if I have 2 different containers of gasses, and they're in thermal contact, how do I work with Boyle's Law? (This is for my thermodynamics course.)
My book says that Boyle's Law together with Avagdro's Law implies that p/n is the same for all ideal gases (where n is particle density, N/V). But this is completely NOT obvious to me. How do I prove this? Is it supposed to be intuitive??
Specifically, my example problem asks this... you have nitrogen at 1.26 kg/m^3 at pressure 1 bar and helium at 0.36 kg/m^3 at pressure 2 bar. Molecular weight of nitrogen = 28 and of helium = 4. Are the two gases in thermal equilibrium?
pV = k
Well, the solution is already given in the book (since it's a sample problem), but it doesn't explain why p/n is the same for all gases at same temperature -- it just states it as if it's obvious or something -- and I don't see why that necessarily is obvious, so... how do I prove that it is true? And am I the only one to whom this is not intuitive??
Thanks a lot!
What is characteristic of ideal gas? Or what are assumptions of kinetic theory of gases?
Dear frustrated student,
I can understand your frustration with trying to compare two different ideal gases using Boyle's Law. It is a common misconception that Boyle's Law only applies to the same gas, but in fact, it can be applied to any ideal gas as long as the temperature and number of moles remain constant.
To prove that p/n is the same for all ideal gases at the same temperature, we can use the Ideal Gas Law, which states that PV = nRT. From this equation, we can see that at constant temperature, p/n is directly proportional to V. This means that for any ideal gas, the ratio of p/n will be the same as the ratio of V.
In your example problem, we can see that the ratio of p/n for nitrogen is equal to 1 bar / 1.26 kg/m^3 = 0.79 bar/kg/m^3. Similarly, the ratio of p/n for helium is equal to 2 bar / 0.36 kg/m^3 = 5.56 bar/kg/m^3. These two ratios are not equal, which means that the two gases are not in thermal equilibrium.
I hope this helps to clarify why p/n is the same for all ideal gases at the same temperature. Keep up the good work in your thermodynamics course!
Related to Apparently easy but super frustrating question about Boyle's Law
1. What is Boyle's Law?
Boyle's Law is a gas law that states that at a constant temperature, the volume of a gas is inversely proportional to its pressure.
2. What is the formula for Boyle's Law?
The formula for Boyle's Law is P1V1 = P2V2, where P1 and V1 represent the initial pressure and volume of a gas, and P2 and V2 represent the final pressure and volume of the gas.
3. How do you solve a problem using Boyle's Law?
To solve a problem using Boyle's Law, you can use the formula P1V1 = P2V2 and plug in the known values for pressure and volume. Make sure that the temperature remains constant throughout the problem.
4. What are the units for pressure and volume in Boyle's Law?
The units for pressure and volume in Boyle's Law can vary, but they must be consistent throughout the problem. Some common units for pressure are atmospheres, pascals, and torr. Common units for volume are liters and milliliters.
5. Can Boyle's Law be applied to all gases?
No, Boyle's Law is only applicable to ideal gases, which means that the gas particles have no volume and do not interact with each other. Real gases may deviate from Boyle's Law at high pressures or low temperatures.
  • Mechanical Engineering
