Comp Sci Appendix C problem -- Machine Language Subtraction
  • Thread starter Thread starter altoaviactus
    Language Machine
The discussion centers on the challenges of performing subtraction in machine language using two's complement representation. Participants highlight the method of inverting the bits of the subtrahend and setting a carry for subtraction. The conversation emphasizes the practical applications of textbooks and resources in understanding these concepts. There is also a mention of the enjoyment derived from using modern emulators for learning. Overall, the thread explores the intricacies of machine language subtraction and the utility of educational materials in mastering these skills.
altoaviactus
This is the application that we have to use https://joeledstrom.github.io/brookshear-emu/ . I am attempting to subtract 16-15. The instruction set is also attached. I'm not very good at 2's complement, but I am trying to figure this out. Addition is much easier and straightforward, but I can't seem to make a good algorithm to make a negative converter. Here are the questions: 1. Using the model CPU demonstrated in class, write code using the simple machine language of Appendix C to solve the following problem: 16 - 15. Store the result in memory location F0.
2.Using the model CPU demonstrated in class, write code using the simple machine language of Appendix C to solve the following problem: 9 + 27 – 16. Store the result in memory location FF.
I think I only need help on one as I could figure out the other from it.
1 RXY LOAD register R with the contents of the memory cell at address XY.
2 RXY LOAD register R with the value XY.
3 RXY STORE the contents of register R at memory location XY.
4 0RS MOVE the contents of register R to register S.
5 RST ADD the integer contents of registers S and T and leave the result
in register R. Integers are stored using two's complement notation.
6 RST ADD the floating-point contents of registers S and T and leave the
result in register R.
7 RST OR the contents of registers S and T and place the result in register R.
8 RST AND the contents of registers S and T and place the result in register R.
9 RST EXCLUSIVE OR the contents of registers S and T and leave the result in register R.
A R0X ROTATE the contents of register R one bit to the right X times.
B RXY JUMP to the instruction located at memory address XY if the
contents of register R equals that of register 0.
C 000 HALT
2010
210F
Can only get this far without running into issues
Hello @altoaviactus ,
:welcome: !​
That's not very far :wink: . At this point you have decimal 16 in register 0 and 15 in register one. Time for some action.
The first issue in question being "How to invert a number in two's complement" -- right ?
Because you studied the two's complement in your textbook or wiki lemma and under "subtraction" were referred to method of complements and there, under practical uses in computers you finally found what to do:
wiki said:
  • If two's complement representation is used, subtraction requires only inverting the bits of the subtrahend and setting a carry into the rightmost bit.
(you can really see the usefulness of textbooks and lecture notes from this: everything is presented in context on a silver platter and you don't have to hop from one huge page to another. Unfortunately I don't have your textbook, just John F Wakerly, Microcomputer architecture and programming from 1981 :biggrin:).
So: which instruction(s) might be useful for register 1 ?
You have 0F sitting there and want something else. Something that you can add to the contents of register 0 using 5RST
[edit] I played with the emulator and had endless fun! I really envy nowadays students for having such nice toys !
Still here ?
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
10K
