Application of derivative rules in physics
In summary: I'm not able to come up with worked examples in physics that use the quotient rule.In summary, the quotient rule and the product rule are the same, but there is a special case for them. David provided a helpful link that explains the derivation of L/Dmax. I will now be looking into this further.
physics_who
Hi everyone, I'm currently working on year 12 maths and am able to answer questions in the maths book for the various rules of differentiation (chain, product, quotient) and can determine which questions should be answered using which rules.
But in the maths book, the questions are presented in the form of equations and there are no word questions in the book I'm using.
The issue I'm having is trying to come up with examples in physics where the quotient rule would be used - like coming up with a worked solution question that requires using the quotient rule in order to solve it (that would be accessible at the year 12 level). Would anyone be able to provide such an example?
While I can solve the maths questions, I don't feel like I can really understand it until I can see it in action, if that makes sense.
The quotient rule:
dy/dx = [v(du/dx) - u(dv/dx)] / v^2
I've done some extensive web searches and have found some good examples for the chain rule and the product rule, but haven't been able to find anything for the quotient rule.
I tried to create my own question using basic kinematics, but haven't had much success.
http://www.ugrad.math.ubc.ca/coursedoc/math100/notes/derivative/chainap.html <- this is a good example of what I'm looking for with regard to the quotient rule, which will hopefully make it clear what I'm hoping to find.
Any help would be much appreciated. Thanks!
In reality, the quotient rule and the product rule are the same...it is just a special case. So, I recommend not treating them like different rules.
If you need to verify, try looking at ## f(x) = \frac{u(x)}{v(x)} ## as the product ##f(x) = u(x) * (v(x))^{-1}##.
This will come up any time it is easier for you to look at a function as a fraction of two other functions, and is simply a matter of convenience.
The angle of attack (α) that corresponds to maximum lift-to-drag occurs where the derivative of the lift function divided by the drag function (with respect to α) equals zero.
Thank you for this, that's very helpful. I do understand your point, but am still hoping to find a worked example for the quotient rule. :)
Thank you, David, this is along the lines of what I'm looking for. I'm currently looking up these formulae to try and construct my own worked example, but would certainly appreciate if anyone would be able to provide a hypothetical example.
Calculate the jerk of something whose mass is changing due to burning fuel (a rocket, car, etc.): A = F(t)/m(t); jerk = A'.
Calculate the rate of change of pressure in a cylinder with a moving piston.
A situation where you would need to find those derivatives are if you are trying to control acceleration or pressure and want to know how often you need to monitor the acceleration or pressure.
EDIT Correction: replaced "jerk" with "acceleration" in prior line.
I was able to find this page that shows the derivation of L/Dmax, which does involve the quotient rule. Thank you!
A situation where you would need to find those derivatives are if you are trying to control jerk or pressure and want to know how often you need to monitor the jerk or pressure.
Thank you for this - I will have a look at these calculations and try to work something out. :)
The quotient rule:
Look up Planck's Law (for the distribution of power vs frequency in blackbody radiation). To find the frequency giving maximum power involves exactly the type of thing you want.
Just think of things in physics where you do some division (estimated_time_to_reach_target=distance/velocity; density = mass/volume; etc.) and imagine situations where the divisor changes with time. You can probably think of many examples.
Good points. And you also need a reason to want to differentiate the quotient of two functions. In the example I offered, the idea is to find the maximum (derivative = zero). In other cases, you might just need a general expression for the rate of change of the ratio of two functions.
Likes FactChecker
Related to Application of derivative rules in physics
1. What is the definition of a derivative in physics?
In physics, a derivative is a mathematical concept that represents the rate of change of a physical quantity with respect to another quantity. It is defined as the slope of a tangent line to a curve at a specific point.
2. What is the importance of using derivative rules in physics?
Derivative rules are essential in physics because they allow us to analyze and understand the behavior of physical systems. They help us calculate rates of change, determine maximum and minimum values, and predict the future behavior of the system.
3. How are the derivative rules applied in kinematics?
In kinematics, derivative rules are used to calculate the velocity and acceleration of an object based on its position and time. The first derivative of position with respect to time gives the velocity, and the second derivative gives the acceleration.
4. Can derivative rules be used in other areas of physics besides kinematics?
Yes, derivative rules are applicable in many other areas of physics, such as thermodynamics, electromagnetism, and quantum mechanics. They are used to analyze and understand the behavior of various physical systems and phenomena.
5. Are there any limitations to using derivative rules in physics?
While derivative rules are powerful tools in physics, they do have some limitations. They may not be applicable in cases where the physical system is highly nonlinear or when the variables involved are not continuous. In such cases, other mathematical methods may be used to analyze the system.
  • STEM Educators and Teaching
