MHB Application of existence and uniqueness theorem
The discussion focuses on applying the existence and uniqueness theorem to the initial value problem (IVP) defined by the differential equation y' = 4x^3y^3 with the initial condition y(1) = 0. To determine the existence and uniqueness of solutions, one must check if the function f(x, y) = 4x^3y^3 is differentiable and if its partial derivative with respect to y is continuous. The participants clarify that the checks should be performed on the function f itself, not on a potential solution. Since f is differentiable and its partial derivative is continuous, the theorem concludes that there is a unique solution to the IVP. Thus, the existence and uniqueness theorem confirms that a single solution exists for the given initial condition.
find_the_fun
Given the differential equation [math]y'=4x^3y^3[/math] with initial condition [math]y(1)=0[/math]determine what the existence and uniqueness theorem can conclude about the IVP.
I know the Existence and Uniquness theorem has two parts 1)check to see if the function is differentiable and 2)check to see if $$\frac{\partial f}{\partial y}$$ is continious. If they both are true you can condlude there is only one solution (a unique solution). If not, then you can't conclude anything.
My problem is I don't understand which function I should be checking. Should I be checking the differential equation it self, or do I first need to solve and and then check the (a) solution?
The initial value problem is of the form:
$$\left\{\begin{matrix}
y'=f(x,y)\\
y(x_0)=y_0
\end{matrix}\right.$$
Therefore, the function $f$ is equal to $4x^3y^3$.
