Application of gradient vector in 3D
In summary: The gradient vector is given by $$\underline{\nabla}T = (30x(4+3x^2+2y^2+z^2)^9, 40y(4+3x^2+2y^2+z^2)^9, 20z(4+3x^2+2y^2+z^2)^9)$$. If we multiply this by -k(x,y,z), then we can choose k(x,y,z) to cancel out some of the coefficients and make the expressions simpler. For example, if we set k(x,y,z) = \frac{1}{10(4+3x^2+2y^2+z^2)^9}, then
CAF123
88
The temperature ##T## in a region of Cartesian ##(x,y,z)-## space is given by $$T(x,y,z) = (4 + 3x^2 + 2y^2 + z^2)^{10},$$ and a fly is intially at the point ##(-5,6,7)##. Find a vector parametric representation for the curve which the fly should move in order to ensure that the temperature it experiences decreases as rapidly as possible.
I have done a 2D analogue of this problem, however, it only asked for the curve in rectangular coordinates and not a vector parametrisation. Furthermore, I was able to get that curve by computing dy/dx which I can't do here.
So, what I have done so far is compute the gradient vector, ##\underline{\nabla}T## and took the negative of this because we want the vector to be pointing in the direction of decreasing values of ##T##. I don't really know where to go from here. I am considering using the Implicit Function Theorem to attain $$\frac{\partial T}{\partial x}, \frac{\partial T}{\partial y}, \frac{\partial T}{\partial z}.$$ Is this good? If I do that, then I would just integrate these three expressions. Any ideas? Many thanks
You are looking for a curve of the form x(t), y(t), z(t). And you want its time derivative to be proportional to -grad T, evaluated at x(t),y(t),z(t). This is a system of ordinary differential equations for three unknown functions. The key here is that the velocity does not have to be the negative gradient, it only needs to be proportional to it. You can use that to make the differential equations very easy to solve.
So the velocity is in the same direction as the negative gradient vector. So I have: $$\frac{dx}{dt} = k(\underline{T} \cdot \hat{x}), k \,\in \,\mathbb{R}$$ and similar expressions for y and z?
Not quite. The factor k need not be a constant scalar. The only requirement is that for all t, the velocity vector is parallel to the negative gradient. The positive scalar k could (and should if you want a simple solution) vary with time.
Also, I am not familiar with the underline notation, but I assume it means negative gradient.
If you have a system of ODE such as
[itex] \frac{d\vec{r}}{dt} = F(\vec{r}) [/itex]
where F(r) is a vector field, then the solution curves are not changed if you multiply F by a scalar function. The parametrizations change, but the image curves do not. In other words, the velocity with which the curve is traversed changes, but the curve itself does not change. The reason is that the curves have to be everywhere tangent to the vector field. That requirement in itself determines the curves and is unchanged by multiplying F by a scalar field as long as the scalar field (function) is never 0. If your scalar field is negative everywhere, it reverses the direction of the curves, but still gives you the same actual curves.
Ok, so something like: $$\frac{dx}{dt} = k(t)(-\underline{\nabla}T \cdot \hat{x})$$
I made an error on notation in the previous post. It is fixed now.
Yes, something like that. Saying k depends on time might have been misleading on my part though. It would have been better to say it depends on time through its dependence on position. k = k(x(t),y(t),z(t)). So really, your k is a function of position.
I suppose this makes sense - as the curve is traced out, the velocity may change in magnitude. However, the resulting differential eqn looks messy: $$ \frac{dx}{dt} = - k(x(t))(10(4+3x^2+2y^2+z^2)^{9} \cdot 6x) $$ Should I do this by separation of variables?
No,
[itex] \frac{dx}{dt} = - k(x,y,z)*20(4+3x^2+2y^2+z^2)^9*3x [/itex]
k depends on all three variables x,y,z (which in turn all depend on t). I am suppressing the dependence on t in the right hand side to make it more readable. Now write down the corresponding equations for y' and z', and then find a function k(x,y,z) that is the most convenient possible choice for making all three equations simpler.
Essentially, we are replacing -grad T with -k(x,y,z)grad T in order to make the vector field simpler.
Vargo said:
No,
$$\frac{dy}{dt} = - k(x,y,z)*20(4+3x^2+2y^2+z^2)^9*2y$$ and $$ \frac{dz}{dt} = - k(x,y,z)*20(4+3x^2+2y^2+z^2)^9*z$$ I am not sure what you mean by finding a function k(x,y,z) to make the vector field simpler. By introducing this k, how does that simplify things?
Thanks.
What I mean is choose a function k(x,y,z) that simplifies the expression. Any choice (as long as it is never 0) will not affect the integral curves. So you are free to substitute anything you like for k(x,y,z). For example, you could try
[itex] k(x,y,z) = 1+|x|^5\cos(y)+z^4. [/itex]
but that would be a poor choice because it would only make your equations more complicated.
Ok, so I could have something like k(x,y,z) = xyz or k(x,y,z) = 1? As long as it's some scalar (function). Or what about ## k(x,y,z) = (4 + 3x^2 + 2y^2 + z^2)^{-9}?##
Now you're catching on.
By doing the integration, I got ##x = (Ae^t)^{1/60}, y= (Be^t)^{1/40}, z = (Ce^t)^{1/20}##?. So ##\underline{r} = x \hat{i} + y\hat{j} + z \hat{k}##
Looks close. But you lost a minus sign somewhere. Your solutions should decay. Also, you have an initial value of (-5,6,7), so you can solve for A,B,C. You could simplify this more by including a factor of 1/20 in your function k.
In the end, I have $$\underline{r} = 7e^{-2t}\hat{i} + 6e^{-3t}\hat{j} -5e^{-t}\hat{k}$$
Related to Application of gradient vector in 3D
1. What is a gradient vector in 3D?
A gradient vector in 3D is a mathematical concept used to represent the direction and magnitude of the steepest increase of a function in three-dimensional space. It is a vector whose components correspond to the partial derivatives of the function with respect to each of the three spatial dimensions.
2. How is a gradient vector used in 3D applications?
In 3D applications, gradient vectors are used to calculate the direction and rate of change of a function at a specific point. This information is useful in various fields such as computer graphics, physics, and engineering for tasks such as surface normal calculations, optimization, and simulation.
3. What is the relationship between gradient vectors and contour maps?
Gradient vectors and contour maps are closely related, as gradient vectors point in the direction of the steepest increase of a function, while contour lines represent points with equal values of the function. The gradient vector at any point on a contour line will be perpendicular to that line.
4. Can gradient vectors be used to find the maximum and minimum values of a function?
Yes, gradient vectors can be used to find the maximum and minimum values of a function in 3D space. The maximum value of a function will occur where the gradient vector is zero, while the minimum value will occur where the gradient vector is pointing in the opposite direction of the steepest increase.
5. How do you calculate the gradient vector of a function in 3D?
To calculate the gradient vector of a function in 3D, you need to find the partial derivatives of the function with respect to each of the three spatial dimensions. These partial derivatives can then be used to form a vector with three components, representing the direction and magnitude of the steepest increase of the function at a specific point.
