Application of one dimensional force - Dynamics
In summary, in this conversation, the problem involves Superman needing to stop a 120-km/hr train in 150 m to prevent it from hitting a stalled car. The train's mass is given as 3.6 x 10^5 kg. To solve this, the initial velocity (Vi) is converted to meters per second (m/s), and then the acceleration is calculated using the formula Vf^2 = Vi^2 + 2a(Xf - Xi). Next, the force required to achieve this acceleration is found using the equation F = Ma. However, an error is made in the calculation and the correct answer, according to the book, is half of the calculated value.
Paul W.
Superman must stop a 120-km/hr train in 150 m to keep it from hitting a stalled car on the tracks. If the trains mass is 3.6 x 10^5 kg, how much force must he exert?
Vi = 33 m/s (120 km/h)
Vf = 0 m/s
Displacement (Xf - Xi) = 150 m
M = 3.6 x 10^5 kg[/B]
Vf^2 = Vi^2 + a(Xf - Xi) - used to calculate the acceleration without a time value.
F = Ma - used to calculate the force required to stop the train with the calculated acceleration.
First convert Km/h to m/s. (120*1000)/60^2 ~ 33 m/s
Then find the acceleration.
A = (Vf^2 - Vi^2)/(Xf - Xi)
A = -(33 m/s)^2 / 150 m ~ -7.3 m/s^s
Now calculate the force required to achieve that acceleration.
F = Ma
F = 3.6 x 10^5 kg* -7.3 m/s^2
F ~ -2.6 x 10^6 N
The answer at the back of the book is half that value. (1.3 x 10^6 N) I don't understand what I'm doing wrong. [/B]
Paul W. said:
[/B]
Oh your work is good but you forgot the 2!
Likes Paul W.
Oh FFS.
Thank you.
Related to Application of one dimensional force - Dynamics
What is a one dimensional force?
A one dimensional force is a force that acts in a single direction, either towards or away from a specific point or object. It is often represented by a straight line and can be measured in units of Newtons (N).
What is dynamics?
Dynamics is the branch of physics that studies the motion and causes of motion of objects. It involves analyzing the forces acting on an object and how those forces affect the motion of the object.
How is one dimensional force applied in real life?
One dimensional force is applied in various real-life scenarios, such as pushing a cart, pulling a door, or throwing a ball. It is also used in engineering and construction to calculate the structural stability of buildings, bridges, and other structures.
What is the relationship between one dimensional force and acceleration?
According to Newton's second law of motion, the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. This means that the greater the one dimensional force applied to an object, the greater its acceleration will be.
How is one dimensional force different from two or three dimensional forces?
One dimensional force only acts in a single direction, while two or three dimensional forces can act in multiple directions simultaneously. This means that one dimensional force can only cause motion in one direction, while multi-dimensional forces can cause motion in multiple directions at the same time.
