Applications of integration: Area and boundaries? (can't understand so
In summary, the problem at hand is to calculate the center of gravity bounded by the two axes and the graph of a given function. After plotting the graph, it becomes clear that the area in question is a triangle with known coordinates. This allows for the boundaries to be determined and the problem to be solved using known equations for center of gravity.
Poppietje
Hey! I'm a complete newbie to integral calculus (and well, to math in general - but I'm trying to learn!) and I have a bit of a problem. I already get the feeling that the solution is ridiculously simple, but my brain just isn't making the connection.
Given are two functions: f(x) = 2x√x and g(x) = -2x + 24 that intersect at points (4, 16)
Problem: Calculate the center of gravity bounded by the two axes and graph of g(x).
The teacher's solution gives the equation A: 1/2 * 12 * 24 = 144 and the integral boundaries are defined from 0 to 12.
Well, the answer is known but my problem is that I can't figure out how it got there. I do know that if an area is bounded by a graph of a function and an axis, then one of the boundaries is set at 0... But I feel that I'm missing something very basic (which wouldn't surprise me, since my math education until now is pretty, uh, bad.)
I guess the problem is that I don't know how to actually *think* about the problem, I'm just aimlessly playing around with the numbers (16 - 4 makes 12! x is 12! Is that the boundary? Why? I don't know!)
If you could kick me in the right direction I would appreciate it a lot! ^^ Thank you.
Hello Pop and welcome to PF.
You're not all that new to math: if you can count, add and subtract, that's quite a bit already!
Some general advice: if confronted with a big problem, chop it up into small pieces and start with one of them.
In this case, f(x) doesn't appear in the actual question. Only g. You can plot it easily: straight line. x=0 gives (0, 24) g=0 gives x = 12, so (12, 0).
You are asked to calculate the center of gravity. What is a releveant equation when you have to do that?
Hey, thank you a lot for your reply! :)
I realized, indeed, that after plotting out the graph, the area in question becomes the area of a triangle between the x- and y-coordinates. Additionally the boundaries became clear as well. And that answers my big question.
This then allows me to proceed with the problem, solving the coordinates for the center of gravity by the known equations for x_z and y_z. :) This part is no problem, just integration.
Thank you again so much! This was just what I needed.
You're welcome :redface:
FAQ: Applications of integration: Area and boundaries? (can't understand so
What are the main applications of integration?
The main applications of integration are in calculating areas under curves, finding volumes of 3D shapes, and solving optimization problems.
How is integration used to find areas under curves?
Integration is used to find areas under curves by breaking the curve into small sections and calculating the area of each section, then adding them together to get the total area.
What are the boundaries in an integration problem?
The boundaries in an integration problem are the limits of the integral, which define the starting and ending points of the area or volume being calculated.
What is the relationship between integration and differentiation?
Integration and differentiation are inverse operations, meaning that integration is used to find the original function when given its derivative, and differentiation is used to find the derivative of a function.
What real-world problems can be solved using integration?
Integration can be used to solve a variety of real-world problems, such as calculating the volume of a tank or determining the optimal shape for a bridge support. It is also used in fields such as physics, economics, and engineering.
