I Applications of measurement of commutativity
askmathquestions
Dang this place has a topology and analysis section too, nice.
This is probably a graduate level topic, but I am by no means an expert on these subjects, just things I learn from wikipedia and other people. The commutator is an operation on two linear operators (most often matrices) of the form ##[A,B] = AB - BA.## This is often touted as a measurement of how "badly" two matrices fail to commute, but I don't think it quite is.
I'd like to research what happens when we induce a matrix norm to the commutator, when the matrix norm of the commutator ##|| [A,B] ||^2## actually returns a specific number, I think that's more of a "measurement" of the commutativity of two matrices.
However, why bother? Are there any theoretical or scientific applications for measuring the size of matrix commutators? Possibly in quantum physics, though I don't know that subject in depth, I hope there are more applications than that.
You have to consider ##A## and ##B## as vector fields. ##[A,B]## measures the gap you get if you flow along ##A## and then ##B##, or the other way around. It doesn't measure how badly matrices commute, it measures how commutative flows along vector fields are.
Okay, that's interesting. What about measuring the commutativity of matrices instead of vectors though? I haven't seen the commutator in the case that ##A## and ##B## are vector fields, but rather matrices.
Yes, but I explained where the comparison comes from, i.e. why people say they measure commutativity.
It is a heuristic rather than a precise definition. It needs a curved space, since ##[A,B]=0## in a flat world. In a flat world, it doesn't matter whether you go left or right in a parallelogram. In a curved world, it does matter.
You have to define a scale before you make a proper definition of what "distance from commutativity" means.
I've never studied differential geometry, but it sounds like this has some kind of fundamental relationship to trajectories and derivatives on various manifolds. Would you be able to illuminate that connection?
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
