What are some real-life applications of overdamping in mechanical devices?
In summary: For a system in equilibrium, the displacement should be zero. The goal is to get the displacement to zero as quickly as possible.If the displacement is initially small, the system will move in the "right" direction and the damping force will try to keep the displacement small. If the displacement is initially large, the system will move in the "wrong" direction and the damping force will try to keep the displacement large.The damping force tries to keep the displacement small by adjusting the damping parameter.
bcrowell
Staff Emeritus
Insights Author
431
It's easy to think of mechanical devices that are underdamped (pendulum, guitar string) or critically damped (automatic door closers, various control systems such as cruise control). But what is a good, simple, pedagogical example of a practical mechanical device that is overdamped, and for which the overdamped behavior is desirable? In a control system, you typically want to get to the equilibrium state as fast as possible, so you would want to tune the damping to be critical.
I'm especially interested in simple examples for which the free rather than the driven response is of interest. (I think there are things called tuned dampers for car engines and skyscrapers that one would like to be overdamped if possible, but I don't know if they are overdamped in practice, and these are examples where you're interested in the driven response.)
Handicap-access door closer mechanisms
Push-button water faucet shut-off valves (like you see in public restrooms)
Recoil return dampers for artillery pieces (the actual recoil absorption is probably critically damped, I would guess)
(basically anything that you want to return slowly to its original position...)
I could be wrong, but I believe these are all designed to be *critically* damped. I've seen both the door closer and the gun mechanisms described as being tuned for critical damping.
I picture each of them as overdamped because the motion looks almost linear (in highly over-damped systems). Critically damped systems have motion that looks almost exponential. BTW, the gun recoil recovery motion that I'm referring to is after the initial recoil is absorbed, and the piece is returning to the forward firing position. I'll see if I can scare up some videos...
http://www.efunda.com/formulae/vibrations/sdof_images/SDOF_OverDamped_Response.gif
You may also want to avoid any overshoot, even if the initial conditions have the system moving in the "wrong" direction. A moderate amount of overdamping might be desirable to achieve that. A textbook analysis of the step response of a system probably assumes the initial velocity is zero.
Your question seems to be about single degree of freedom systems, and tuned dampers are basically 2 DOF systems.
They work on a different principle from the simple idea of "damping out an oscillation". The basic function is to transfer energy from where it can cause damage (e.g. torsional vibration of the engine crankshaft or motion of the skyscraper) to somewhere else where it is harmless and can then be dissipated (e.g. an oscillating metal ring for the crankshaft damper, or a massive pendulum for the skyscraper.). The "energy absorber" is not likely to be overdamped, because it has to be able to move around to gain kinetic energy. If it was heavily overdamped, it would behave more like an additional mass rigidly connected to the crank or skyscraper, which would change the system's vibration frequency a bit, but would not take much energy out of the system.
Remember that real dampers are usually nonlinear devices, so the notion of "critical damping" is rather idealized. For example a friction damper generates a force that is approximately constant, not a force proportional to velocity. Hysteretic damping (strain energy in the material converted to heat) removes a constant proportion of the strain energy in each cycle of vibration, independent of the vibration frequency. A damping force caused by "air resistance" will probably be proportional to velocity squared. A damper that forces fluid through an orifice isn't linear either.
For a real-world lightly damped system, the nonlinear behavior of the damper doesn't have much effect on the approximation that the motion is harmonic, and for practical purposes you can model the system with a linear damper that takes out the same amount of energy per cycle as the real-world nonlinear one. But that linear approximation breaks down as the damping level increases.
The best real-world examples of linear damping are probably electrical, not mechanical. Ideal resistors are very good approximations to real ones.
That was not very carefully worded (and might even be interpreted wrongly) so to spell out the math:
Consider the critically damped system ##\ddot x + 2 \dot x + x = 0## with ##x(0) = 1##.
The general solution is ##x(t) = (1 + at)e^{-t}## where ##a## depends on ##\dot x(0)##.
If ##a >= 0##, ##x## is always positive, i.e. the response does not overshoot the equilibrium position ##x = 0##.
But if ##a < 0##, the response passes through 0 when ##t = -1/a##, overshoots, and then returns towards 0.
For the "door closer", that corresponds to what happens if you slam the door shut instead of just letting it go.
If the system is overdamped, overshooting can still happen but it needs a bigger (negative) initial velocity to cause it.
In an application like computer controlled machining, or landing a plane by autopilot, overshooting the desired response could have worse consequences than slamming a door shut!
Likes 1 person
Aha, excellent examples!
FAQ: What are some real-life applications of overdamping in mechanical devices?
1. What are some real-world applications of overdamping?
Some common applications of overdamping include shock absorbers in vehicles, damping systems in buildings to reduce earthquake vibrations, and cushioning in furniture and mattresses.
2. How does overdamping differ from underdamping and critical damping?
Overdamping occurs when a system returns to equilibrium without oscillating, while underdamping results in oscillations around the equilibrium point. Critical damping is the minimum amount of damping needed to prevent oscillations.
3. What factors affect the level of overdamping in a system?
The level of overdamping in a system is affected by the mass, stiffness, and damping coefficient of the system. A higher mass or stiffness will result in a higher level of overdamping, while a higher damping coefficient will decrease the level of overdamping.
4. Can overdamping be beneficial in certain situations?
Yes, overdamping can be beneficial in situations where oscillations need to be minimized or eliminated. This can be useful in sensitive equipment, vehicles, and structures to prevent damage or discomfort.
5. How is overdamping mathematically represented?
Overdamping is represented by a second-order differential equation with two distinct real roots. The general solution for an overdamped system is a combination of exponential functions, which result in a gradual return to equilibrium without oscillations.
