(Applied Force)⋅d= 1/2mv^2 versus (Net Force)⋅d= 1/2mv^2
  • Thread starter Ocata
In summary, the conversation discusses the concept of work and kinetic energy in relation to an applied force and resistive force on an object. The work done by the applied force is equal to the net work done on the object, which can be calculated using the work-energy theorem. The efficiency of the activity is also mentioned, with only 10% of the work being converted to kinetic energy while the rest is converted to heat. The type of work done by the net force is referred to as useful work, but it can also be seen as wasted energy in certain situations.
Ocata
198
Suppose I have this object of 100kg and apply 1000N for 100 seconds with 900N of resistance force for the duration of the applied force.
I calculated the distance to be 5000m.
So the Work I do on the object is F*d = 1000N*5000m = 5 million J
However, I calculated the final velocity to be 100m/s
so the Kinetic Energy is 500,000 J
and since [itex]\frac{1}{2}mv_{f}^{2} - \frac{1}{2}mv_{i}^{2} [/itex]
That must mean Work must equal 500,000 J as well.
The only way I can make F*d = 500,000 is if I use [itex]F_{net}[/itex]:
[itex]F_{net}*d = 100N*5000m = 500,000 J [/itex]
My question is, how do I refer to this type of work?
Applied Force * Distance = Work I did on the object
Net Force * Distance = What type of work? Or is it not referred to as work?
You could call it useful work, since the efficiency of your activity is only 10%: 0.5 MJ is converted into kinetic energy and 4.5 MJ (900 N x 5000 m) is converted into (waste) heat.
Likes Ocata
It sounds like you forgot about the work done against the resistive force?
The work you did (5,000,000J) breaks down as..
4,500,000 joules against the resistive force (900 * 5000 = 4,500,000)
and
500,000 joules converted to KE
total
5,000,000 Joules
What you call the 500,000 joules converted to KE is up to you. In some situation that might be the useful work. In others it might be the wasted energy. Depends on the situation. If this was a drag racing car you could argue both were useful.
Likes Ocata
If I understand correctly, the work I did on the object is Force * distance in the direction of motion.
The Work that the friction did on the object is Force * distance in the opposite direction.
And the useful Work or KE (or the energy the box has gained that it can now apply to another object) is the net Force * distance.
Like so: 100N * 5000m = 500,000J
_______
l l
900N * 5000m = 4,500,000J <------------ l l-----------> 1000N * 5000m = 5,000,000J
l_______lTherefore, if I know the Force applied and the Force of resistance then finding kinetic energy is basically as easy as finding net force.
Hope I understand correctly.
The change in KE is always equal to the net work. This result is known as the "work-energy theorem". Maybe you look it up if you did not hear about it yet.
Likes Ocata
Wow those dashes and l's did not come out how it originally looked in the text box when I wrote it. My apologies for that confusing mess!
It was supposed to be an illustration of a box with force vectors * distance.
Let me please restate that post entirely without the butchered illustration:
______________________________________________________________________________
And the useful Work or KE (or the energy the box has gained that it can now apply to another object) is the net Force * distance. 1000N * 5000m = 5,000,000J ---------------------> Work I apply to the object in the positive direction<------------------- 900N * 5000m = 4,500,000J Work the road applies to the object in the negative direction
100N * 5000m = 500,000J ----------> Net amount of Work done on the object, which can also be calculated by Fd = 1/2 mv^2 = KE
Therefore, if I know the Force applied, the Force of resistance, and the distance of an object's motion, then finding kinetic energy is a similar process to finding net force.
_________________________________________________________________________________Does this make sense?
Note: Please disregard post # 4 as I thought I'd be able to create a free body diagram using some dashes and letter l's, but it turned into a mess more than anything.
Btw, Nasu,
My physics book doesn't mention the term work-energy theorem. It just gives the equation fd=1/2 mv^2. It does not go into detail to the degree of specifying a final and initial velocity. It just presents the equation as though all velocities start from 0. Then it goes straight into an example problem without any description. I just wanted to get a better sense of it which I am very appreciative of being able to seek further understanding here. Thank you.
FAQ: (Applied Force)⋅d= 1/2mv^2 versus (Net Force)⋅d= 1/2mv^2
What is the difference between applied force and net force in the equations (Applied Force)⋅d= 1/2mv^2 versus (Net Force)⋅d= 1/2mv^2?
Applied force refers to the external force that is acting on an object, while net force takes into account all the forces acting on the object, including the applied force, as well as any other forces such as friction or gravity.
How do these equations relate to the concept of work?
Both equations represent the work-energy theorem, which states that the work done on an object is equal to its change in kinetic energy. In these equations, (Applied Force)⋅d and (Net Force)⋅d represent the work done, and 1/2mv^2 represents the change in kinetic energy.
Can these equations be used for both linear and rotational motion?
Yes, these equations can be used for both linear and rotational motion, as long as the appropriate variables are used. For linear motion, distance (d) and velocity (v) are used, while for rotational motion, angular displacement (θ) and angular velocity (ω) are used.
How do these equations change for objects with varying mass?
The equations do not change for objects with varying mass, as mass (m) is already included in the equations. However, the values for mass will affect the final values for kinetic energy and work.
Can these equations be applied to real life scenarios?
Yes, these equations are commonly used in real life scenarios to analyze the motion of objects and calculate the amount of work done on them. For example, they can be used to determine the amount of force needed to move an object a certain distance or to calculate the speed of a moving object.
