mistabry
- 12
A box of mass m = 4.5 kg rests on a larger box of mass M = 26.0 kg, which is at rest on a frictionless surface. The coefficient of static friction between the two boxes is μs = 0.51. An ideal string runs between the two boxes around a fixed pulley. What is the maximum force F that can be exerted on the lower box without causing the boxes to slide?
fs=μ*|N|
I drew 2 free body diagrams. For first mass, I had Tension point left, Force point right, Normal force up, W down. For second mass, I had Tension point left, Friction point right, Normal force up, W down.
I would think since the surface was frictionless, T = F = fs, but that didn't work out so well D;
