Applying boundary conditions on an almost spherical body
In summary, the conversation discusses solving the Laplace equation in 3D with azumuthal symmetry and using perturbation theory to find an approximate solution. The boundary condition leads to a series of boundary value problems, with each one being solved using separation of variables. However, the problem is not separable unless a curvilinear coordinate system is defined such that the boundary is a surface of constant coordinate.
hunt_mat
1,798
33
I am solving the Laplace equation in 3D:
[tex]\nabla^{2}V=0[/tex]
I am considering azumuthal symmetry, so using the usual co-ordinates [itex]V=V(r,\theta)[/itex]. Now suppose I have two boundary conditions for [itex][V[/itex], which are:
[tex]V(R(t)+\varepsilon f(t,\theta),\theta)=1,\quad V\rightarrow 0\quad\textrm{as}\quad r\rightarrow\infty[/tex]
where [itex]\varepsilon\ll1[/itex]. The boundary condition does lead itself to separation of variables does it? Would a more general Green function approach be more suitable?
Since ##t## is a parameter I will ignore it. One classic way to try and find an approximate solution is to use perturbation theory. Your boundary condition can be Taylor expanded, $$
1 = V(R + \epsilon \, f(\theta),\theta) = V(R, \theta) + \epsilon \, f(\theta) V_r(R, \theta) + \frac{1}{2}\left( \epsilon \, f(\theta) \right)^2 V_{rr}(R, \theta) + \ldots $$
where ##V_r = \partial V / \partial r ##, etc, and look for a solution of the complete boundary value problem of the form,
$$ V(r,\theta) = V^{(0)}(r,\theta) + \epsilon V^{(1)}(r,\theta) + \epsilon^2 V^{(2)}(r,\theta) + \ldots $$
Here ##V^{(k)}(r,\theta)## is simply a function, and the number ##k## tells us what power of ##\epsilon## is in front of it. We plug the expansion for ##V(r,\theta)## into Laplace's equation and collect terms with the same power of ##\epsilon## to find, that for all ##k## we must have ##\nabla^2 V^{(k)}(r,\theta)=0##. Likewise, we plug the expansion for ##V(r,\theta)## into the Taylor expanded boundary condition and collect terms with the same power of ##\epsilon##. This leads to a series of boundary value problems. The first few boundary conditions are
\begin{eqnarray}
V^{(0)}(R,\theta) & = & 1 \\
V^{(1)}(R,\theta) & = & -f(\theta) V^{(0)}_r(R,\theta)\\
V^{(2)}(R,\theta) & = & -f(\theta) V^{(1)}_r(R,\theta) - \frac{1}{2}f^2(\theta) V^{(0)}_r(R,\theta)\\
\vdots
\end{eqnarray}
That is, you first solve ##\nabla^2 V^{(0)} = 0## with ##V^{(0)}(R,\theta) = 1##, then solve ##\nabla^2 V^{(1)} = 0## with ##V^{(1)}(R,\theta) = - f(\theta) V^{(0)}_r(R,\theta)##, etc.
You might be able to use separation of variables for each of these. If ##\epsilon## is small enough you probably just need to solve the first few problems, then add up the solutions accordingly.
Jason
Forgot to address this above.
Unless you are able to define a curvilinear coordinate system such that your boundary is a surface of constant coordinate (such as a sphere in spherical coordinates, ellipse in ellipsoidal coordinates, etc.), then the problem is not separable.
FAQ: Applying boundary conditions on an almost spherical body
What are boundary conditions?
Boundary conditions are physical or mathematical constraints that are applied to a system in order to solve a problem. They specify the behavior of a system at its boundaries or interfaces with other systems.
Why are boundary conditions important in scientific research?
Boundary conditions are crucial for obtaining accurate and meaningful results in scientific research. They help to define the limits of a system and ensure that the model or experiment is realistic and applicable to real-world situations.
How do boundary conditions affect the behavior of an almost spherical body?
Boundary conditions play a significant role in the behavior of an almost spherical body. They can affect the stress, deformation, and stability of the body, as well as its interactions with external forces or other bodies.
What are some common boundary conditions applied to an almost spherical body?
Some common boundary conditions applied to an almost spherical body include fixed or free surfaces, prescribed displacements or forces, and contact conditions with other bodies. These conditions can vary depending on the specific problem being studied.
How are boundary conditions determined for an almost spherical body?
The determination of boundary conditions for an almost spherical body involves a combination of theoretical analyses, experimental measurements, and numerical simulations. The specific methods used will depend on the complexity of the problem and the available resources.
