Applying General Lorentz Boost to Multipartite Quantum State
In summary: Wigner, "Theory of the electron and of the radiation from the sun", Proc. Natl. Acad. Sci. U.S.A. 20 (1933), 719-723.
Emil_M
46
TL;DR Summary
How to find unitary transformation corresponding to a general Lorentz transformation, that will perform a change of reference frame on a multipartite quantum state
I would like to apply a General Lorentz Boost to some Multi-partite Quantum State.
I have read several papers (like this) on the theory of boosting quantum states, but I have a hard time applying this theory to concrete examples.
Let us take a ##|\Phi^+\rangle## Bell State as an example, and apply a general Lorentz Boost $$
\Lambda=\left[\begin{array}{cccc}{\gamma} & {-\gamma \beta_{x}} & {-\gamma \beta_{y}} & {-\gamma \beta_{z}} \\ {-\gamma \beta_{x}} & {1+(\gamma-1) \frac{\beta_{x}^{2}}{\beta^{2}}} & {(\gamma-1) \frac{\beta_{x} \beta_{y}}{\beta^{2}}} & {(\gamma-1) \frac{\beta_{x} \beta_{z}}{\beta^{2}}} \\ {-\gamma \beta_{y}} & {(\gamma-1) \frac{\beta_{y} \beta_{x}}{\beta^{2}}} & {1+(\gamma-1) \frac{\beta_{y}^{2}}{\beta^{2}}} & {(\gamma-1) \frac{\beta_{y} \beta_{z}}{\beta^{2}}} \\ {-\gamma \beta_{z}} & {(\gamma-1) \frac{\beta_{z} \beta_{x}}{\beta^{2}}} & {(\gamma-1) \frac{\beta_{z} \beta_{y}}{\beta^{2}}} & {1+(\gamma-1) \frac{\beta_{z}^{2}}{\beta^{2}}}\end{array}\right]
$$ to this state.
Now, as I understand, we represent this Lorentz Boost as some unitary ##U(\Lambda)## in our Hilbert Space, in order to be able to boost our quantum state:$$|\Phi^{+'}\rangle=U(\Lambda)|\Phi^+\rangle$$
Unfortunately, I have found no paper that detailes just how exactly this unitary is found, they all simply state that it must always exist.
So, how would I find ##U(\Lambda)## that boosts some quantum state – like ##|\Phi^+\rangle## – from some inertial frame of reference ##S## to another ##S'##?
Thanks!
It depends on the Hilbert space you’re working with. If it’s a Fock space then in the momentum basis the representation of the lorentz boosts simply boost the three momentums the usual way. If your particles have spin it’s more complicated and you need to boost the polarization states as well. There are partial discussions in Peskin and Schroeder for the spin-0 and 1/2 cases.
@HomogeneousCow: Your described action of boosts on the momenta and spins of particles is valid only in systems of non-interacting particles. When particles interact with each other, then the boost generator becomes interaction-dependent (in a sense, similar to the interaction-dependent Hamiltonian).
This is true for interacting dynamics in the instant form, as explained in
P. A. M. Dirac, "Forms of relativistic dynamics", Rev. Mod. Phys. 21 (1949), 392.
Eugen.
Related to Applying General Lorentz Boost to Multipartite Quantum State
1. What is a General Lorentz Boost?
A General Lorentz Boost is a mathematical operation that describes the transformation of coordinates between two reference frames that are moving at a constant velocity relative to each other. This concept is an essential part of Einstein's theory of special relativity.
2. How does a General Lorentz Boost apply to multipartite quantum states?
In quantum mechanics, a multipartite quantum state is a state that describes the collective behavior of multiple particles. A General Lorentz Boost can be applied to these states to describe how they would appear in different reference frames moving at different velocities.
3. What is the significance of applying a General Lorentz Boost to multipartite quantum states?
Applying a General Lorentz Boost to multipartite quantum states allows us to better understand the behavior of these states in different reference frames. This can help us make more accurate predictions and measurements in experiments involving multiple particles.
4. Are there any limitations to applying a General Lorentz Boost to multipartite quantum states?
One limitation is that the General Lorentz Boost assumes that the particles are in a vacuum and not interacting with any other external forces. In reality, particles are often influenced by various forces, which can complicate the application of the boost.
5. Can a General Lorentz Boost be applied to any type of multipartite quantum state?
Yes, a General Lorentz Boost can be applied to any type of multipartite quantum state, regardless of the number of particles or their properties. However, the calculations involved may become more complex as the number of particles increases.
