Applying Heisenberg Picture Confusion
In summary, the lecturer is using a trick to get the same result as taking the commutator of all four terms. You can take the commutator of all four terms, and you should get the same result.
nateHI
146
I was trying to follow http://www.youtube.com/watch?v=dCua1R9VIiQ&p=EFD655A9E0B979B7&playnext=1&index=54" lecture at the 4:15 mark but am having a little difficulty. In particular, why doesn't he have to take the commutator of all four of the terms you get when you square (p-eA).
Is he using :
[tex]\partial[/tex]q/[tex]\partial[/tex]t = [tex]\partial[/tex]H/[tex]\partial[/tex]p and the chain rule? If so, why doesn't he differentiate what's inside the parantheses of the Hamiltonian?
-Nate
Is he using :
-Nate
it's a trick. you can take the commutator of all four terms, and you should
get the same result. the trick is [x, f(p)] = i h-bar f'(p). where prime here
is derivative wrt p.
lets check // (i'll assume x,p 1 dimensional to not worry about the vector stuff
but it's no big deal)
(p - eA)^2 = p^2 -epA -eAp + e^2A^2
so [x,(p - eA)^2] = [x, p^2] -e [x, pA] -e[x, Ap] + [x, e^2A^2 ]
now we can use the rule [A, BC] = [A,B]C + B[A,C].
[x,p^2] = [x,p]p + p[x,p] = 2 i h-bar p
[x,pA] = [x,p]A + p[x,A] = i h-bar A + 0
[x,Ap] = [x,A]p + A[x,p] = 0 + A(i h-bar)
[x,A^2] = 0
so [x,(p-eA)^2] = 2 i h-bar p - e (i h-bar A) - e (i h-bar A) = (2 i h-bar)(p - eA).
now take derivative of f(p)= (p-eA)^2 wrt p => f'(p) = 2(p-eA)
[x,f(p)] = i h-bar f'(p) = i h-bar 2 (p-eA).
it all works.
OK that clears it all up. Thanks!
FAQ: Applying Heisenberg Picture Confusion
1. What is the Heisenberg Picture in quantum mechanics?
The Heisenberg Picture is one of the two main formulations of quantum mechanics, along with the Schrödinger Picture. It is a mathematical framework that describes the time evolution of quantum mechanical systems.
2. How is the Heisenberg Picture different from the Schrödinger Picture?
In the Heisenberg Picture, the operators (representing observables) are time-dependent, while the state vectors remain constant. In the Schrödinger Picture, the state vectors are time-dependent, while the operators remain constant.
3. What is the importance of applying the Heisenberg Picture in quantum mechanics?
Applying the Heisenberg Picture allows us to simplify and solve complex problems in quantum mechanics. It also helps us better understand the relationship between observables and states in a system.
4. How does the Heisenberg Picture handle uncertainty in quantum mechanics?
The Heisenberg Picture takes into account the uncertainty principle, which states that the more precisely we know the position of a particle, the less precisely we can know its momentum, and vice versa. This is represented by the commutation relations between operators in the Heisenberg Picture.
5. Can the Heisenberg Picture be applied to all quantum mechanical systems?
Yes, the Heisenberg Picture can be applied to all quantum mechanical systems, including those with time-dependent Hamiltonians. It is a powerful tool for solving problems and making predictions in quantum mechanics.
