Applying mutiple resistors to create an 18k
  • Thread starter Thread starter Megasundato
    Resistors
To create an 18k resistor, one can use combinations of other resistors in series or parallel. A common approach is to use two 36k resistors in parallel, which will yield the desired 18k value. The discussion highlights that 18k is a standard resistor value found in both E12 and E24 series, suggesting that it should be available at electronics supply stores. If local stores like RadioShack do not carry it, seeking a dedicated electronics supply or hobby shop is recommended. Understanding resistor combinations and values can help in achieving the required resistance for projects.
Megasundato
30
Hello. my robot requires an 18k resistor at one point. my problem is that I don't have one and my radioshack has never heard of it.
anyway, I was wondering on how to create one. I know that adding in a series circuit it's just R1+R2... and I think that parallel circuits add with the reciprocal.
so how can one get an 18k. Someone told me that I could make a parallel circuit with a 22k and some 1ks, but I don't think that would work. I know that I could create one in a serial circuit, but that might take a lot of resistors.
thanks for the help.
18k is very much a standard value. In higher tolerance parts many more values may be available, but even the most basic 10% parts should be available in decade multiples of the following.
1, 1.2, 1.5, 1.8, 2.2, 2.7, 3.3, 3.9, 4.7, 5.6, 6.8, 8.2
5% resistors follow the E24 series: there are 24 resistor values in a decade. That's fancy speak for there being 24 logarithmically-spaced values from 10 to 91 ohms (and 24 from 100 to 910 and so forth).
You can calculate the value of two parallel resistances as follows:
\frac{1}{R_{parallel}}=\left(\frac{1}{R_{1}}+\frac{1}{R_{2}}\right) or
R_{parallel}=\left(\frac{1}{R_{1}}+\frac{1}{R_{2}}\right)^{-1}
Three resistors in parallel add the same way:
\frac{1}{R_{parallel}}=\left(\frac{1}{R_{1}}+\frac{1}{R_{2}}+\frac{1}{R_{3}}\right)
A handy thing to remember is that two equal resistors in parallel have an equivalent resistance of half their value (three in parallel having a third, and so on). So if you don't have an 18k, you can put two 36k resistors in parallel (which should be more plentiful--hit search to do the calculation):
http://www.google.com/webhp?q=(1/36+1/36)^-1
Yep, and both the E12 and the E24 series include 18k. So it's pretty hard to believe that radioshack has never heard of it.
Maybe the sales guy was just trying to sell some batteries or an extended warranty?
In any case, to the OP, I recommend finding a real electronics supply / hobby shop in your area (assuming one still exists).
thanks for your help. I see how I can do this now.
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
