Applying Newton's 2nd to a rocket
  • MHB
  • Thread starter Dustinsfl
  • Tags
    Rocket
In summary, the acceleration of the rocket, \(a_r\), can be calculated using the equation \(a_r = \frac{V_s \cdot C}{m}\), where \(V_s\) is the velocity of the rocket powered by steam, \(C\) is the steam's rate of change in mass, and \(m\) is the mass of the rocket. This equation can be derived from Newton's 2nd and 3rd laws.
Dustinsfl
2,281
A rockt with mass \(M\) is sitting motionless in space. The rocket is powered by steam with velocity \(V_s\) and mass per time \(C = \frac{dm}{dt}\). Write an equation for the rockets acceleration in terms of \(M, {} V_s\), and \(C\).
So \(\mathbf{F}_s = \mathbf{F}_r\) by Newton's 3rd. By Newton's 2nd,
\begin{align}
\mathbf{F}_s &= \mathbf{F}_r\\
\frac{d(mV_s)}{dt} &= \frac{d(mV_r)}{dt}\\
m\frac{dV_s}{dt} + V_s\frac{dm}{dt} &= m\frac{dV_r}{dt} + V_r\frac{dm}{dt}\\
V_s\cdot C &= ma_r
\end{align}
Here we assumed the steam isn't accelerating and \(\frac{dm}{dt} = 0\) on the RHS. I understand assuming the steam acceleration is zero, but why is the \(\frac{dm}{dt}\) on the RHS zero and not \(C\)?
Mathematics news on Phys.org
The \(\frac{dm}{dt}\) term on the RHS is zero because the mass of the rocket does not change over time. The steam is the only thing that is changing in mass, so its rate of change, \(C\), is the only factor that needs to be accounted for on the right side of the equation.
FAQ: Applying Newton's 2nd to a rocket
How does Newton's 2nd law apply to a rocket?
Newton's 2nd law, also known as the law of acceleration, states that the force acting on an object is equal to its mass multiplied by its acceleration. In the case of a rocket, this means that the force generated by the rocket's engines (thrust) must be greater than the force of gravity pulling it down. This allows the rocket to accelerate and overcome Earth's gravitational pull.
What is the relationship between mass and acceleration in a rocket?
According to Newton's 2nd law, the acceleration of an object is directly proportional to the force acting on it and inversely proportional to its mass. This means that as the mass of a rocket decreases (as fuel is burned), its acceleration increases.
How does the mass of the rocket affect its flight?
The mass of a rocket is a critical factor in its flight because, as mentioned before, it is directly related to its acceleration. A lighter rocket will accelerate faster and require less thrust to overcome gravity, making it more efficient. However, a heavier rocket may have more fuel and therefore have a longer flight time.
Can Newton's 2nd law be used to calculate the trajectory of a rocket?
Yes, Newton's 2nd law can be used to calculate the trajectory of a rocket. By considering the forces acting on the rocket (thrust, gravity, air resistance), the rocket's mass, and its initial velocity, the trajectory can be calculated using Newton's laws of motion and principles of physics.
What are some real-world applications of Newton's 2nd law in rocket science?
Newton's 2nd law is essential in the design and operation of rockets. It is used to calculate the amount of thrust needed to overcome gravity, the amount of fuel required for a specific mission, and the maximum acceleration the rocket can handle. It is also used to predict the trajectory of a rocket and make necessary adjustments during flight to ensure a successful launch and landing.
