Applying nodal analysis on this simple circuit
In summary: I made a mistake in my previous calculation. The correct value for i_{x} is actually \frac{(10 - i_{3})}{3}A. Sorry for the confusion.In summary, there was a discussion about solving a circuit problem using nodal analysis and mesh analysis. The person asking for help was initially using nodal analysis but was suggested to use mesh analysis instead. However, they were still unsure of how to solve the problem using mesh analysis and asked for clarification. It was later discovered that the initial solution using nodal analysis was incorrect and the correct value for the variable i_{x} was given.
PainterGuy
940
70
Hi, :)
Almost all the details you will find in the given link below:
http://img171.imageshack.us/img171/9797/nodalysis1.jpg
You will find the expected (or, target answers) in the top right corner.
As you can see my value for V1 is wrong. It should have been 80V according to the answer given in the book. I have checked my equations several times but I found nothing wrong with them. Please help me with it. Many thanks for your help.
Cheers
3rd line: At V2: Ix = 4Ix + I2 --> 0 = 5Ix + I2 ... silly mistake, 4Ix - Ix = 3Ix!
7th line: At V3: ... --> (V1)/2 - (V3)/2 = (V3)/6 + (V2) --> 1/2(V2) = -2/3(V3) ... how do you turn - V(3)/2 - (V3)/6 = (V2) - (V1)/2 into 1/2(V2) = -2/3(V3), specifically the combining of V2 and V1?
PainterGuy said:
Hi, :)
Cheers
Are you required to use nodal analysis for the solution?
That current source in the LHS means that you could quickly solve this with 2 equations using mesh analysis.
Just a thought, I usually take the easiest route possible.
Out of curiosity, could you demonstrate which two equations you would use?
Considering the other two mesh current variables, the third variable from the dependent current source and the super mesh it doesn't look that much easier either way, unless you're familiar with one method over the other I guess.
Many thanks, Zryn, for helping wit this problem, and also with the one from yesterday. Thanks a lot.
jegues, I was required by the book to use nodal analysis. To be honest I don't know if mesh analysis is applicable.
Once again many thanks. Hope you guys will keep on helping me.
Cheers
If we label the leftmost mesh with a mesh current i1, the rightmost i2 and the mesh above it i3 we can apply mesh analysis to this problem.
By inspection,
[tex]i_{1} = 10A[/tex]
Followed by a simple KCL gives,
[tex]i_{x} = \frac{-10}{3}A[/tex]
Now we write the equation for the supermesh,
[tex]5i_{3} + 10i_{2} - 7i_{1} = 0 \quad \text{Equation 1} [/tex]
Looking at the dependent source,
[tex]4i_{x} = i_{3} - i_{2} \quad \text{Equation 2}[/tex]
Now I realize that this gives 3 equations as well, but when I had quickly glanced at the circuit I didn't notice that the other current source was a dependent source because it wasn't drawn with the correct diamond symbol.
[tex]
[/tex]
Wouldn't the current through the 3R resistor be equal to [tex]10A - i_{3}[/tex] by KCL at node 1, thus making the KCL at node 2 result in [tex]i_{x} =4i_{x} + 10 - i_{3}[/tex] --> [tex]i_{x} = \frac{(i_{3} - 10)}{3} [/tex]?
Yes you are absolutely correct.
FAQ: Applying nodal analysis on this simple circuit
What is nodal analysis?
Nodal analysis is a method used to analyze electrical circuits by determining the voltage at each node (junction point) in the circuit. It is based on Kirchhoff's Current Law, which states that the sum of the currents entering a node must equal the sum of the currents leaving the node.
How do you apply nodal analysis on a simple circuit?
To apply nodal analysis, you first need to identify all the nodes in the circuit. Then, you set up equations based on Kirchhoff's Current Law for each node, using the given values for resistors and current sources. Finally, you solve the equations to find the voltage at each node.
What are the advantages of using nodal analysis?
Nodal analysis is a powerful tool for analyzing circuits because it can be used to solve circuits with any number of nodes and current sources. It also provides a systematic approach to solving circuit problems, making it easier to identify and correct errors.
Are there any limitations to nodal analysis?
One limitation of nodal analysis is that it can only be used to analyze circuits with independent voltage sources. It also assumes that all the nodes in the circuit are known, so it may not be suitable for circuits with unknown nodes or complex topologies.
Can nodal analysis be used for circuits with multiple voltage sources?
Yes, nodal analysis can be used for circuits with multiple voltage sources. In these cases, the equations for each node will include the voltage sources in addition to the resistors and current sources. The voltage sources must also be independent for nodal analysis to be applicable.
