MHB Applying the central limit theorem
The discussion focuses on applying the central limit theorem (CLT) to estimate the probability that 40 components, each with a gamma distribution for failure time, will last at least 6 years. The mean failure time for one component is calculated as 0.5 days, leading to a total mean of 20 days for 40 components. The variance for one component is 0.05, resulting in a total variance of 2 for the sum of the components. Using the CLT, the probability that the total time exceeds 2191.5 days is expressed through the complementary error function, indicating that this probability is extremely small. The analysis concludes that achieving 6 years of functionality with the given parameters is highly unlikely.
oyth94
Suppose the time in days until a component fails has the gamma distribution with alpha = 5, and theta = 1/10. When a component fails, it is immediately replaced by a new component. Use the central limit theorem to estimate the probability that 40 components will together be sufficient to last at least 6 years. *Assume that a year has 365.25 days.
Re: applying the central limit theorem
If the time is expressed in days, then the mean time before a failure for one component is $\mu = \alpha\ \theta = \frac{1}{2}\ \text{day}$ and for 40 components is $40\ \mu = 20\ \text{days}$... in this case to guarantee 6 x 365.25 = 2191.5 days of continuous functionality of the equipment seems a little problematic...Kind regards
$\chi$ $\sigma$
Hint: We want the probability that $Y = \sum_{i=0}^{40} X_i$ is greater than 6 years, where each $X_i$ has a Gamma distribution with known parameters. By the Central Limit Theorem the distribution of $Y$ is approximately Normal. You can use the mean and variance of $X_i$ to find the mean and variance of $Y$. From there, it should be easy.
Given n r.v. $X_{1}, X_{2},..., X_{n}$ with the same distribution, mean $\mu$ and variance $\sigma^{2}$, then for n 'large enough' the r.v. $S = X_{1} + X_{2} + ... + X_{n}$ is normal distributed with mean $\mu_{S} = n\ \mu$ and variance $\sigma^{2}_{S} = n\ \sigma^{2}$. In this case is...
$\displaystyle \mu= \alpha\ \theta = \frac {1}{2} \implies \mu_{S} = 40\ \mu = 20$
$\displaystyle \sigma^{2}= \alpha\ \theta^{2} = \frac{1}{20} \implies \sigma^{2}_{S}= 40\ \sigma^{2} = 2$
The probability that S is greater than x days is...
$\displaystyle P\{S > x\} = \frac{1}{2}\ \text{erfc}\ (\frac{x - \mu_{S}}{\sigma_{S}\ \sqrt{2}})\ (1)$
... and for x = 2191.5 we have...
$\displaystyle P\{S > x\} = \frac{1}{2}\ \text{erfc}\ (1085.75)\ (2)$
Of course the quantity (2) is numerically unvaluable and an approximate value is given in...
http://www.mathhelpboards.com/f52/unsolved-statistic-questions-other-sites-part-ii-1566/index4.html#post12076
In any case is a number 'very small'... exceeding our imagination (Wasntme)...Kind regards $\chi$ $\sigma$
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
