A Applying the Laplace transform to solve Differential equations
LagrangeEuler
Is it possible to apply Laplace transform to some equation of finite order, second for instance, and get the differential equation of infinite order?
A laplace transform turns a differential equation into an algebraic equation.
If you had a term like ##\sin t\,y##, you could expand ##\sin t## as a series and take the Laplace transform of the result term by term, which would give you a bunch of derivatives of Y(s). I'm not sure why you'd want to do that though or if doing so is valid.
It is only in the case when you have a differential equation with constant coefficients.
Do you have an example in mind?
##y''(t)+\sin(t)y(t)=0##, where ##y(0)=A##, ##y'(0)=B##. If I apply the Laplace transform would I get the differential equation of infinite order?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
