"Approximating Basis" -- Is there a contemporary term?
In summary, the term approximating basis is used by author Harry Floyd David to describe a basis for a countably infinite dimensional linear space that is close to being orthogonal.
Ziva
The term approximating basis is used by author Harry Floyd David is his book Fourier Series and Orthogonal Functions
on page 56:
So I have looked in other books on functional analysis, harmonic analysis...and even on Google and I cannot find any other text reference that uses this term. This book is very sophisticated, but a bit dated and unfortunately has no bibliography. So my question is this:
What is the contemporary term for an approximating basis of a countably infinite dimensional linear space over ℝ(or ℂ) equipped with an inner product?
Office_Shredder said:
These are often called a Schauder basis.
https://en.m.wikipedia.org/wiki/Schauder_basisThough note even Wikipedia doesn't totally believe that, as the section in Hilbert spaces on orthonormal bases just calls them a basis without further clarification
https://en.m.wikipedia.org/wiki/Hilbert_space
I am not sure that the text from the book attached to the OP indeed defines a Schauder basis. Note that the ##\epsilon##-close linear combination may depend on ##\epsilon##.
So, given ##f \in V## there need not exist a (unique) infinite sequence of scalars such that the associated series converges to ##f## in the norm of ##V##. (I think this is also what the remark in the book at the end refers to.) On the other hand, the definition of a Schauder basis does require this.
Likes Infrared
I agree. I think ##\{1,x,x^2,...\}## would be an approximating basis for ##C[0,1]## according to the OP's definition, but not a Schauder basis. Every continuous function on a compact interval can be uniformly approximated by polynomials (this is a theorem of Weierstrass), even without being analytic.
Likes S.G. Janssens
You're right, I missed that last part.
I guess in a Hilbert space the basis will be a Schauder basis if and only if it's at least mostly orthogonal. If the basis is orthogonal then it's clear adding future terms doesn't adjust your best choice of coefficients for the earlier terms.
If e.g. none of the terms are orthogonal, then if you think about it in terms of an orthogonalized version of the basis, every time you add a new term you're basically adjusting all the older coefficients in the orthogonal basis, so you can't possibly stabilize on the right set. If the vectors are close enough to orthogonal then this is maybe not a problem.
As an extreme example, if you can partition it into a disjoint union of finite subsets such that every vector is orthogonal to everyone outside of its partition, then it will still be a Schauder basis I think. Or if you pick an orthogonal basis, and then add ##a_n v_1## to each ##v_n## for some choice of ##a_n## that converges sufficiently quickly to 0,I think you can just cleverly pick the coefficient on the first vector to cancel out all the future adjustments the latter vectors will make.
Here is a bit more about the definition in the copied book text in the OP.
  1. Assume that ##V## is an infinite-dimensional real or complex normed linear space. Then ##V## has an approximating basis if and only if ##V## is separable. (##\Longrightarrow## is not difficult, and ##\Longleftarrow## is a bit more difficult because, starting from a countable dense subset, you need to extract a linearly independent subset.)
  2. Assume that ##V## is also complete, so it is a Banach space. If ##V## has a Schauder basis, then ##V## is separable. The converse is false, but this is difficult. Enflo gave the first counterexample in Acta Mathematica 130, 1973, p. 309 - 317.
  3. Finally, assume that ##V## is also a Hilbert space. Then separability is equivalent to existence of an orthonormal basis, which is clearly a Schauder basis.
So, in the case of a Hilbert space, existence of an approximating basis IS equivalent to existence of a Schauder basis. In the case of a Banach space that is not an inner product space, the situation is more difficult and as outlined above.
Likes Keith_McClary
The last line in the text cited in #1 shows that it is not a Schauder basis
In Hilbert space orthonormal basis exists even in the nonseparable case see for example Yosida Functional Analysis. Orthonormal basis in Hilbert space is not exactly the same as Schauder basis. Just for separable case any orthonormal basis is a Schauder basis
With post #1 in mind, in post #7 I consider orthonormal basis to be countable. This is the more elementary definition. For the OP: See for example at the top of p. 28 of Basic Classes of Linear Operators by Gohberg, Goldberg, and Kaashoek, Birkhäuser, 2003. Of course wrobel is right that extensions and generalizations are possible.
Then, in a Hilbert space, there is the equivalence between: separability and existence of an approximating / orthonormal / Schauder basis. For the OP: See Theorem 17.1 on p. 35 of the above book.
As a side remark, I find this book a very nice introductory read, in line and probably at the level of the book mentioned in post #1.
FAQ: "Approximating Basis" -- Is there a contemporary term?
What is the meaning of "approximating basis"?
"Approximating basis" refers to a mathematical concept in which a set of vectors is used to approximate a larger set of vectors. It is commonly used in linear algebra and numerical analysis.
How is "approximating basis" different from "basis approximation"?
The two terms are essentially the same, but "approximating basis" is more commonly used in mathematical contexts, while "basis approximation" is more commonly used in computer science and engineering contexts.
What is the purpose of approximating basis?
The purpose of approximating basis is to simplify complex mathematical problems by using a smaller set of vectors to represent a larger set. This can make calculations and computations more efficient and manageable.
Can approximating basis be used in real-world applications?
Yes, approximating basis is used in various real-world applications, such as image and signal processing, data compression, and machine learning. It allows for efficient and accurate representation of large datasets.
Are there any limitations to approximating basis?
Yes, there are limitations to approximating basis. The accuracy of the approximation depends on the quality and size of the original set of vectors, and there may be errors or discrepancies in the approximation. Additionally, the process of approximating basis can be computationally intensive and may not always be feasible for large datasets.
19K
15K
