MOHD ZAKI
- 1
using binomial theorem can I write sqrt(1+(d^2)/(x^2)) = 1+ .5(d^2)/(x^2)?
d is a variable. X known constant.
For a first approximation, yes. But you can do better:MOHD ZAKI said:using binomial theorem can I write sqrt(1+(d^2)/(x^2)) = 1+ .5(d^2)/(x^2)?
"Approximation to sqrt(1+(d^2)/(x^2))" is a mathematical expression used to approximate the square root of 1 plus the square of a given ratio.
This expression is important in a variety of mathematical and scientific fields, as it can be used to estimate values and make approximations in complex equations.
The expression is typically calculated using a series of mathematical operations, such as division, multiplication, and square root functions.
This expression is commonly used in physics, engineering, and other scientific fields to estimate values and make approximations in complex equations and calculations.
Yes, there are limitations to using this expression as it is an approximation and may not always provide an exact solution. Additionally, it may not be suitable for certain types of equations or calculations.
