Arbitrariness of the surface involved in the displacement current
In summary: That is correct.The two terms would add up to the current charge in the wire alone, in order to give the same circulation along the loop, right?
FranzDiCoccio
342
41
I was thinking of a standard, high school level discussion of the displacement current. The need for introducing this quantity is demonstrated by considering a circuit with a charging capacitor, and (for the sake of simplicity) a circular loop whose axis is along the (straight) wire carrying the current to one of the capacitor plates. There is no dielectric in the capacitor.
Using (again, for the sake of simplicity) Biot and Savart's law one shows that the circulation of the magnetic field around the loop is non zero, because the wire is carrying a current.
However, there seems to be a paradox with (standard) Ampere's Law. Indeed, the circulation of the magnetic field should be proportional to the charge current piercing any surface spanned by the loop. But this works only if one chooses a surface pierced by the wire. If, instead, one chooses surface "enclosing" the capacitor plate attached to the wire, there is no charge current.
Thus Ampere's law seems to "fail", because the circulation of the field is clearly non-zero.
This is solved by including a "displacement current" term in Ampere's law. This displacement current is proportional to the flux of the electric field through the surface. For the first surface, there is no electric field and hence no displacement current. For the second surface there is no current, but the flux of the electric field provides the displacement current.
In all of the discussions I've found, the surfaces are not entirely arbitrary, though. The "second" surface always entirely encloses the capacitor plate.
So I was wondering: "what if the second surface is still not pierced by the wire, but encloses only a portion of the plate?".
To make things more definite, think of this situation: S1 and S2 form the surface of a truncated cone. S1 is the circle enclosed by the loop, and it is also the "bottom lid" of the truncated cone. S2 is formed by the lateral surface and the top lid of the cone, which is between the capacitor plates.
This is basically described by this figure on the wikipedia page about the displacement current. In this case, S2 entirely encloses the capacitor plate.
Now think a surface S3 that is qualitatively similar to S2, but with a much smaller top lid, so that its lateral surface intersects the plate.
Since the flux through S3 is smaller than that through S2, there would be a displacement current but, unlike the previous case, it would be smaller than the charge current, and hence could not account for the entire circulation of the magnetic field by itself.
The only answer I could think of is that there should be a residual charge current flowing radially through the capacitor plate.
In other terms, the surface is not pierced by the wire, but by the plate which, in a way, also carries a charge current.
Hence in this case Ampere's law would have both terms, a current charge term and a displacement term.
Am I making any sense?
That is correct. Both terms are generally needed for a complete description. The “textbook” examples deliberately pick special surfaces that do one or the other, but arbitrary surfaces may need both.
Ok, and in the textbook example with the capacitor, the two terms would add up to the current charge in the wire alone, in order to give the same circulation along the loop, right?
Related to Arbitrariness of the surface involved in the displacement current
1. What is the concept of arbitrariness of the surface involved in the displacement current?
The arbitrariness of the surface involved in the displacement current refers to the fact that the surface chosen to calculate the displacement current can be arbitrary, meaning it can be any closed surface within the circuit. This is because the displacement current is a property of the electric field, which is continuous and can flow through any surface.
2. Why is the concept of arbitrariness important in understanding the displacement current?
The concept of arbitrariness is important because it allows us to calculate the displacement current through any convenient surface, rather than being limited to a specific surface. This makes it easier to apply the displacement current concept to different circuits and situations.
3. How does the arbitrariness of the surface affect the calculation of the displacement current?
The arbitrariness of the surface does not affect the calculation of the displacement current, as the value of the displacement current remains the same regardless of the surface chosen. However, it does affect the ease of calculation, as choosing a more convenient surface can make the calculation simpler.
4. Can the arbitrariness of the surface be applied to all circuits?
Yes, the concept of arbitrariness of the surface can be applied to all circuits as long as they have a closed path for the electric field to flow through. This includes both simple and complex circuits.
5. How does the concept of arbitrariness relate to the concept of Ampere's law?
The concept of arbitrariness is closely related to Ampere's law, as both involve choosing an arbitrary surface to calculate a quantity (displacement current or magnetic field, respectively). However, Ampere's law is limited to simple circuits with steady currents, while the arbitrariness of the surface allows for the application of the displacement current concept to more complex circuits and situations.
  • Electromagnetism
  • Electromagnetism
