Arbitrary Subset of A^n - Is it necessarily an affine algebraic set?
  • MHB
  • Thread starter Math Amateur
  • Tags
    Set
In summary, the conversation discusses the definition and properties of affine algebraic sets in elementary algebraic geometry. The participants also question whether any arbitrary subset of the affine plane can be considered an affine algebraic set and provide counterexamples to show that this is not the case. They also discuss the concept of zero functions and how they relate to affine algebraic sets.
Math Amateur
MHB
3,998
48
I am trying to gain an understanding of the basics of elementary algebraic geometry and am reading Dummit and Foote Chapter 15: Commutative Rings and Algebraic Geometry ...
At present I am focused on Section 15.1 Noetherian Rings and Affine Algebraic Sets ... ...
I need someone to help me to fully understand the definition of an affine algebraic set ... ...
D&F explain and define an affine algebraic set in the following text ... ...View attachment 4750
View attachment 4751My question regarding the above definition is this:
Does any arbitrary subset (that is any subset) of the affine plane \(\displaystyle \mathbb{A}^n\) qualify as an affine algebraic set ...
I was thinking maybe that it does because ... ...
If we have a set \(\displaystyle A_1\), say that has no non-zero functions with zeros at each of its points, then could we regard the function corresponding to the zero polynomial as having zeros at each of the points of \(\displaystyle A_1\) ... ... so that the set of functions {\(\displaystyle z\)} where \(\displaystyle z\) is the zero function is zero on all points of \(\displaystyle A_1\) ... and hence \(\displaystyle A_1\) qualifies as an affine algebraic set ... ... I suspect that something is wrong with my analysis above ... but what exactly ...
Can someone clarify this issue for me please ... ...
Peter
No, it's completely false that any subset of $\Bbb A^n$ appears as an affine algebraic set (also called affine variety).
First, let's review the definition : For some subset $S \in k[x_1,\cdots, x_n]$, the affine variety corresponding to it is the common zero locus of all polynomials in $S$. That is, $V = \{(a_1, \cdots, a_n) \in \Bbb A^n : f(a_1, \cdots, a_n) = 0\}$. If $S$ is a singleton, we get zero locus of a single polynomial in $\Bbb A^n$. This is called a hypersurface.
Thus, you can visualize an affine variety as intersection of (not necessarily finitely many) hypersurfaces in $\Bbb A^n$. As a side-note, it's a fact that any affine variety can be realized as intersection of finitely many hypersurfaces - this is Hilbert's basis theorem.
OK, so now that we are done reviewing the definitions, let's get back to your question. Why should it be true that any subset of $\Bbb A^n$ is an affine variety? Let $U \subset \Bbb A^n$ be an arbitrary subset of $\Bbb A^n$. You can of course consider the set of all functions vanishing on $U$. Call the set $S \in k[x_1, \cdots, x_n]$. However, what you don't know is whether functions in $S$ vanishes on places other than $U$. By definition, however, functions in $S$ on the affine variety $\mathcal{Z}(S)$ doesn't vanish anywhere else. So $U$ might not necessarily be an affine variety.
So, there's no reason for what you say to be true. To get an explicit example, the subset $\Bbb A^n - \{(0, 0, \cdots, 0)\}$ of $\Bbb A^n$ is not an affine variety. The proofs are quite involved, and require much more than basic commutative algebra. As a side-note, it is sometimes desired that locally closed subsets of affine varieties be varieties. Thus, we introduce the notion of quasi-affine varieties.
If we have a set A1, say that has no non-zero functions with zeros at each of its points, then could we regard the function corresponding to the zero polynomial as having zeros at each of the points of A1 ... ... so that the set of functions {z} where z is the zero function is zero on all points of A1 ... and hence A1 qualifies as an affine algebraic set ... ..
Ah, but note that your "zero function" vanishes not only on $A_1$, but in all of $\Bbb A^n$. To prove that $A_1$ is affine, you have to find a set of functions $S$ which vanish only on $A_1$ - that is $A_1$ is the whole zero locus of the functions in $S$.
K
Mathbalarka,
Thanks for your very interesting and helpful post ...
I am now thinking and reflecting over what you have written ...
Thanks again,
Peter***EDIT***Can I just confirm something that I think you have said ...
I think you a saying that there are some subsets of affine space that are not algebraic sets ... is that correct?If it is correct can you specify some examples ...?
Yes, that is correct. I have given an example in my answer :
Hi Mathbalarka,
Indeed you did give such an example ... Thanks ...
Peter
FAQ: Arbitrary Subset of A^n - Is it necessarily an affine algebraic set?
What is an arbitrary subset of A^n?
An arbitrary subset of A^n refers to any subset of the n-dimensional affine space, where A is a field. This means that the subset can contain any combination of points, lines, curves, or other geometric objects.
What is an affine algebraic set?
An affine algebraic set is a subset of an n-dimensional affine space that can be described by polynomial equations. This means that all the points in the set satisfy a set of polynomial equations, and conversely, any set of points that satisfy these equations can be considered an affine algebraic set.
Is every arbitrary subset of A^n an affine algebraic set?
No, not every arbitrary subset of A^n is necessarily an affine algebraic set. For a subset to be an affine algebraic set, all the points in the set must satisfy a set of polynomial equations. If there are points in the subset that do not satisfy these equations, then it is not an affine algebraic set.
What is the importance of affine algebraic sets in mathematics?
Affine algebraic sets play a significant role in algebraic geometry and other areas of mathematics. They provide a geometric interpretation of solutions to polynomial equations, and many problems in algebraic geometry can be reduced to studying affine algebraic sets. They also have connections to other areas of mathematics, such as number theory and topology.
Can affine algebraic sets be used in practical applications?
Yes, affine algebraic sets have practical applications in fields such as computer graphics, image processing, and cryptography. They can be used to model and solve real-world problems, and their connections to other areas of mathematics make them a powerful tool for solving complex problems.
