Danishk Barwa
- 5
I had created a formula on arc of a circle...How can I publish it ..So that people see it and decide is it important or not.
Out of idle curiosity, what is your formula?Danishk Barwa said:I had created a formula on arc of a circle...
My formula is in terms of distance between starting and ending point of arc(x). And breadth of arc (distance between mid point x and mid pointFactChecker said:I assume that you are talking about a formula for the arc length that does not use the radius or angle. My first question is how one can even specify an arc without the radius and the angle (in one form or another)?
Please suggest me how to publish itMark44 said:Out of idle curiosity, what is your formula?
So ##x## is the length of the chord across the arc? Calling the distance from its midpoint to the centre of the circle ##p##, I make the arc length $$2\sqrt{(x/2)^2+p^2}\tan^{-1}(x/2p)$$Danishk Barwa said:My formula is in terms of distance between starting and ending point of arc(x). And breadth of arc (distance between mid point x and mid point
YesFactChecker said:What is your concern about showing it here? Do you think there is some copyright privilege that you will give up and that someone will steal it?
No..That's not correct ...You please tell me how and where to publish itIbix said:So ##x## is the length of the chord across the arc? Calling the distance from its midpoint to the centre of the circle ##p##, I make the arc length $$2\sqrt{(x/2)^2+p^2}\tan^{-1}(x/2p)$$
Since you do not wish to divulge the formula you have created, we have no way of discerning whether it is useful or original.Danishk Barwa said:You please tell me how and where to publish it
An arc formula without the use of radius and angle is a mathematical equation that calculates the length of an arc on a circle without using the traditional measurements of radius and angle.
The arc formula without the use of radius and angle is derived using the Pythagorean theorem and trigonometric functions such as sine, cosine, and tangent.
The main advantage of using an arc formula without the use of radius and angle is that it allows for more flexibility in calculations, as it does not rely on specific measurements. This can be especially useful in situations where the radius or angle is unknown or difficult to measure accurately.
Yes, an arc formula without the use of radius and angle can be used for any type of arc, as long as the measurements of the arc are known. This includes both minor and major arcs on a circle.
While an arc formula without the use of radius and angle can be useful in certain situations, it does have its limitations. It may not be as accurate as traditional methods and may not work for more complex curves or arcs on non-circular shapes.
