Arc length in polar coordinates
In summary, the formula ds=ρdθ is not correct for calculating arc length in polar coordinates. It assigns a zero length to any radial line, such as the line from (0,0) to (0,1) in Cartesian coordinates. This is because it is a limiting case and only applies for motion along a circular arc where dr/dθ = 0.
Gianmarco
42
I know that an arc length in polar coordinates can be computed by integrating $$\int ds$$ using the formula ##ds=\sqrt{\rho^2 + \frac{dr}{d\theta}^2}d\theta##. But, seeing that ##s=\rho\theta## and ##ds = \rho d\theta##, why is it wrong to calculate arc lengths with this expression for ##ds##?
The formula ds=ρdθ is not correct for arc length. It assigns a zero length to any radial line, such as the line from (in Cartesian coordinates) (0,0) to (0,1).
Likes Gianmarco
Right. Thanks
The case of motion along a circular arc is a limiting case. Take your expression
## ds=\sqrt{\rho^2 + \frac{dr}{d\theta}^2}d\theta ##
and ask what happens if we confine motion to a circular arc. In that specific case, ## \frac{dr}{d\theta} = 0 ## and you see the familiar formula for the length of arc along a circular arc emerges, ## ds = \rho d\theta ##.
Related to Arc length in polar coordinates
What is arc length in polar coordinates?
Arc length in polar coordinates is a measure of the distance along a curve in a two-dimensional polar coordinate system. It is determined by the angle and radius of the curve.
How is arc length calculated in polar coordinates?
The formula for calculating arc length in polar coordinates is L = ∫√(r^2 + (dr/dθ)^2)dθ, where r is the radius and dr/dθ is the derivative of the radius with respect to the angle.
What is the difference between arc length and arc measure in polar coordinates?
Arc length is a measurement of the distance along a curve, while arc measure is a measurement of the angle subtended by the arc at the center of the polar coordinate system.
Can arc length be negative in polar coordinates?
No, arc length cannot be negative in polar coordinates as it represents a physical distance and cannot have a negative value.
How is arc length used in real-world applications?
Arc length in polar coordinates is used in various fields such as engineering, physics, and mathematics to calculate the distance traveled by a moving object along a curved path. It is also used in navigation and GPS systems to determine the distance between two points on a curved surface.
  • Calculus
  • Calculus
