Archimedes principle - special case
In summary, the balloon will take off with a weight hanging to it if the temperature of the air in the balloon is greater than the temperature of the air outside the balloon.
Lucky7
We have a chinese lantern (balloon) made of paper, cylinder shaped with the following sizes:
base diameter - 45 cm, height - 70 cm. Mass of the balloon is 57 g (21 g from this is mass of "fuel" - the fuel is wax paper!). Fuel is then ignited at the centre of the base, which is open. Therefore the balloon will soar. The question is, how much additional weight can be hung to the balloon and the balloon still takes off. Outside temperature is 5 °C (Let us denote it as cold air).
Just see the text.
First I can compute volume of the balloon, which is of course V = π*r2*h = π*22.52*70 cm3 = 111330.189662 cm3≈0.11133m3.
Now the gravitational force of air pressed up by the balloon gives the magnitude of buoyancy:
Gcold_aircold_air*V*g = 1.2697*0.11133*g≈1.38723 N.
Now we should determine the volume of the fuel, which is
Vfuel= mfuelfuel=0.021/650 = 0.00003 m3.
Now we will compute Ghot_airhot_air*(V-Vfuel)*g = 1.1277*0.11130*9.871373 ≈ 1.23175 N. Now we can use Archimedes principle:
Gcold_air = Ghot_air + m*g + M*g, and we want to solve this equation for M, which is our burden, that can be carried:
M = (Gcold_air-Ghot_air-m*g)/g, which gives us M≈-0.04116 kg, which is rubbish...
There are just too many determinants, that were omitted:
1) temperature of hot air in the ballon, I chose 40 °C, but how can I know? What if it is 60 °C, then the density would be higher, but how can I know?
2) It would be best if all fuel would just burn out, then the temperature would be the highest and the mass the lowest, so should I wait till the fuel is burn out and only after that I bind the burden?
3) I omitted the air pressed up by the wax paper and the burden.
4) ... inf)
There are just too many...
I'd be so much grateful for your help!
Do you know the energy content of the fuel and the specific heat capacity of air? That may allow you to calculate the temperature of the air in the balloon after the fuel is burnt. Some assumptions may have to be made!
This is all I know, we should probably make some of our own assumptions, yeah...
Since you only need it to take off eventually, yes, you can restrict attention to the time at which the fuel is almost gone. I suspect that assuming all the heat stays in the balloon will give a significant overestimate of the temperature. You could calculate the volume of gas from the combustion products, assume that mixes uniformly with the original air, find the resulting expansion, and hence find how much heat is lost by spillage out of the envelope. (There'll also be radiative losses, but they're probably a lot less.)
Of course, the gases in the balloon will no longer be just hot air - there'll be a lot of CO2, affecting the density.
Hello,
I would like to provide some additional insights and considerations to your solution attempt.
1) Temperature of hot air: You are correct in stating that the temperature of the hot air inside the balloon will affect its density and therefore its buoyancy. However, in this case, we can assume that the hot air will be at a relatively constant temperature throughout the duration of the flight. This is because the fuel (wax paper) will continue to burn and produce hot air, maintaining a fairly consistent temperature inside the balloon. Therefore, for the purpose of this calculation, we can assume a constant temperature of the hot air.
2) Burning of fuel: It is true that the mass of the balloon will decrease as the fuel burns, which will affect its buoyancy. However, since we are only interested in determining the maximum additional weight that can be hung to the balloon, we can assume that the fuel will burn out completely before the balloon reaches its maximum carrying capacity. This means that we can use the initial mass of the balloon (57 g) and the mass of the fuel (21 g) in our calculations.
3) Air pressed up by the wax paper and burden: These factors can be taken into account by considering the volume of the balloon that is occupied by the fuel and the additional weight. This will slightly decrease the overall volume of the balloon and therefore affect its buoyancy.
4) Other factors: As you mentioned, there are many other factors that can affect the maximum carrying capacity of the balloon, such as wind, air pressure, and the shape and material of the burden. These factors can be difficult to account for in a theoretical calculation and may require experimental testing to determine the exact maximum carrying capacity.
In conclusion, while your solution attempt is a good starting point, there are several other factors that need to be taken into consideration in order to accurately determine the maximum additional weight that can be hung to the balloon. It may be helpful to conduct experiments with different weights and conditions to get a more precise answer.
Related to Archimedes principle - special case
1. What is Archimedes principle - special case?
Archimedes principle - special case is a specific application of Archimedes principle that states that the buoyant force acting on a submerged object is equal to the weight of the fluid that is displaced by the object.
2. How is Archimedes principle - special case different from the general Archimedes principle?
The general Archimedes principle states that the buoyant force acting on an object is equal to the weight of the fluid it displaces, regardless of whether the object is fully or partially submerged. The special case only applies to objects that are fully submerged in a fluid.
3. What are the conditions for Archimedes principle - special case to be valid?
The special case of Archimedes principle is valid when the object is completely submerged in a fluid and the fluid is at rest. The object must also have a uniform density throughout and there should be no other forces acting on the object.
4. Can Archimedes principle - special case be applied to objects with irregular shapes?
Yes, Archimedes principle - special case can be applied to objects with irregular shapes as long as the object is fully submerged and the fluid is at rest. The volume of the object can be determined by measuring the volume of the displaced fluid.
5. What are some practical applications of Archimedes principle - special case?
Some practical applications of Archimedes principle - special case include determining the volume of irregularly shaped objects, calculating the density of an object, and designing ships and submarines to have the right amount of buoyancy to float in water.
