Archimedes' rule that area of a parabola is 4/3 times an inscribed triangle
In summary: A = ∫(c,a) (x^2 - (x+c)) dxIntegrating this, we get:A = (x^3/3 - cx) |c to a= (a^3/3 - ac) - (c^3/3 - ac)= (a^3 - c^3)/3= (a - c)(a^2 + ac + c^2)/3Since b = c, we can rewrite this as:A = (a - b)(a^2 + ab + b^2)/3= (a - b)(a^2 + ab + a^2)/3= 2(a - b
runner07
Let ABC be a piece of a parabola. The point B is chosen such that the tangent to the parabola at B is parallel to the line AC. Archimedes proved the Area of parabola inside ABC is 4/3 times the triangle ABC. Prove this using calculus
The integral from a to c (Where pt A=(a,a^2), pt B=(b,b^2), and pt C=(c,c^2)) of (x^2)-(x+c)
I have been trying to figure this out for hours. I know you can assume the parabola to be in the standard form y=x^2 without loss of generality because the problem relies on ratios of areas. And from this, I thought you could assume the segment AC has standard form y=x+c. Then, since we are looking for area, we could use the method of area between two curves, which is why I feel like the integral from a to c of (x+c)-(x^2) would be right. But when I calculate this, it should end up looking something like 4/3(base*height*1/2) and it definitely doesn't look that way. Any help would be greatly appreciated!
Thank you for your question. I will try my best to guide you through the solution using calculus.
First, let's define the parabola as y = x^2, where the focus is at the origin (0,0) and the directrix is the line y = -1. Let's also assume that the points A, B, and C have coordinates (a,a^2), (b,b^2), and (c,c^2) respectively.
Since the tangent to the parabola at B is parallel to the line AC, we can say that the slope of the tangent at B is equal to the slope of the line AC. Using the slope formula, we have:
m = (b^2 - a^2)/(b - a) = (c^2 - a^2)/(c - a)
We can simplify this to get:
b + a = c + a
Therefore, b = c.
Now, let's find the equation of the tangent line at B. We know that the slope of the tangent at any point on the parabola is given by the derivative of the parabola at that point. So, the slope of the tangent at B is given by:
m = dy/dx = 2b
Since we know that b = c, we can rewrite this as:
m = 2c
Using the point-slope form of a line, we can write the equation of the tangent line at B as:
y - b^2 = 2c(x - b)
Now, let's find the intersection points of this tangent line and the parabola. We can substitute the equation of the tangent line into the equation of the parabola to get:
x^2 = 2cx - c^2 + b^2
Since b = c, we can simplify this to:
x^2 = 2cx - c^2 + c^2
x^2 = 2cx
This is a quadratic equation with two solutions: x = 0 and x = 2c. Since we are only interested in the portion of the parabola between points A and C, we can ignore the solution x = 0. Therefore, the x-coordinate of point C is 2c.
Now, we can use the method of area between two curves to find the area of the parabola inside the triangle ABC. The area is
Related to Archimedes' rule that area of a parabola is 4/3 times an inscribed triangle
1. What is Archimedes' rule about the area of a parabola?
Archimedes' rule states that the area of a parabola is equal to 4/3 times the area of an inscribed triangle within the parabola.
2. How did Archimedes come up with this rule?
Archimedes discovered this rule by using a method called the "method of exhaustion," which involves inscribing and circumscribing polygons within a shape to approximate its area. By using this method, he was able to determine the relationship between the area of a parabola and an inscribed triangle.
3. Can this rule be applied to all parabolas?
Yes, this rule applies to all parabolas, regardless of their size or orientation. As long as a parabola can be inscribed with a triangle, this rule will hold true.
4. How is this rule useful in mathematics?
This rule is useful in calculating the area of a parabola, which has many real-world applications in fields such as physics and engineering. It also demonstrates the geometric relationship between the area of a parabola and an inscribed triangle.
5. Are there any other rules or formulas related to parabolas?
Yes, there are several other rules and formulas related to parabolas, such as the vertex form, focus-directrix relationship, and the quadratic formula. These rules can be used to find other properties of parabolas, such as the vertex, focus, and directrix.
  • General Math
