Are 1/2" pipelines reliable for process streams?
  • Thread starter DoItForYourself
  • Tags
    Process
In summary, the conversation discusses the use of 1/2" LTCS pipes for a sample point and the suggestion to switch to 3/4" pipes due to concerns of reliability. The department decided to make the switch and the new sample point is now operating without problems. The question of whether 1/2" pipes are reliable for sample points and the possible reasons for avoiding small pipe sizes are also brought up. However, the piping specification states that all pipe sizes within the class are in compliance with ASME B31.3 and have the same design pressure, temperature, and corrosion allowance. Therefore, the use of smaller pipes would not have caused any problems.
DoItForYourself
Hi,
Last year, I had designed 1/2" LTCS (Low Temperature Carbon Steel) pipes for a sample point (for propylene). The mechanical engineer recommended that we increase the diameter of the pipes, because as he said this size is used only in tubing and for instrumentation reasons and not in process or other streams. However, the company that built the plant had constructed many sample points with pipes of this size (Note : The pipes are supported adequately).
Our department finally supposed that the problem is that the lines of this size are not reliable enough and decided to construct 3/4" pipes for the sample point. Now, the new sample point is in place and operates without problems.
But the question still remains : Are 1/2" pipes reliable and suitable to be used for sample points? And why?
If anyone has any experience on this subject, they are welcome to express their opinion.
Thank you
What does "reliable" mean in this context.
This sounds to me like a personal preference issue.
Likes DoItForYourself
I think they meant that fouling or clog may occur easier because of the small size of the pipes. In my opinion, if the service is clean (like propylene), there is not any problem. In addition, all the sample points have been operating successfully since 2000.
Perhaps, if the service is a heavy hydrocarbon (for example tar or asphalt), clogs may occur and that's why they avoid small pipe sizes (smaller than 3/4") in the refinery.
I was just wondering if there is another reason that small pipes must be avoided.
Could be due to operating pressure or corrosion life, the wall thickness of the 3/4" pipe is greater than the 1/2" pipe. See "ANSI B31 Code for Pressure Piping" (or its successor if there is one, this is from an old reference.)
This would be a possible problem.
However, the piping specification (which states clearly that it is in compliance with ASME B31.3-Code for pressure piping) states that the size range for the pipes of this class is 1/8" - 20". The design pressure, the design temperature and the corrosion allowance are the same for all the pipes of this class (from 1/8" to 20") and go above our needs.
So, I would say that there would not have been any problem, even if I had used 1/8" or 1/4" pipes. The only difference would have been the time needed to fill the sample cylinder (more time to fill it).
Likes Tom.G
FAQ: Are 1/2" pipelines reliable for process streams?
Are 1/2" pipelines suitable for carrying all types of process streams?
No, 1/2" pipelines are not suitable for carrying all types of process streams. They are generally used for low-pressure and low-flow applications, and may not be able to handle corrosive or abrasive materials.
How do 1/2" pipelines compare to larger pipelines in terms of reliability?
Generally, larger pipelines are considered to be more reliable than 1/2" pipelines. This is because larger pipelines have a higher flow capacity and can handle a wider range of process streams, making them less susceptible to clogging and other issues.
Are there any specific safety concerns when using 1/2" pipelines for process streams?
Yes, there are some safety concerns to consider when using 1/2" pipelines for process streams. These pipelines have a smaller diameter, which means they may not be able to handle high pressures and temperatures. This can increase the risk of leaks and potential hazards.
What factors should be considered when deciding whether to use 1/2" pipelines for process streams?
Several factors should be considered when deciding whether to use 1/2" pipelines for process streams. These include the type of process stream, flow rate, pressure and temperature requirements, and the potential for corrosion or abrasion. It is important to consult with an expert and conduct thorough testing before making a decision.
How can the reliability of 1/2" pipelines for process streams be improved?
The reliability of 1/2" pipelines for process streams can be improved by using appropriate materials, regular maintenance and inspection, and implementing safety measures such as pressure and temperature monitoring. It is also important to carefully consider the design and installation of these pipelines to ensure they can effectively handle the intended process stream.
