Are BJT transistors voltage or current controlled?
In summary, a diode is a material that allows electrons and holes to move freely and emit light when they meet, depending on the doping of the material. If the doping of the material is the same as the doping of the region where the holes and electrons meet, there is no light emission. If the doping of the material is not the same, light emission can occur.
fisico30
374
Hello Forum,
question about BJT transistors: some books say that they are current (base current) operated...
Some other books state that the emitter-collector current is controlled by the voltage between the base and the emitter...which one is correct?
FET are voltage controlled...
Holes are not really carriers, correct? They are just empty places that can be filled by electrons...
Also, a transistor, in general, can act as a switch (ON or OFF) or as an amplifier...
But it is not an active device that produces extra energy: it simply acts like a switch, but instead of being a binary switch (only ON or OFF), it acts as a continuous switch...that is what is mean by amplification: the transistor allows more or less current in an analog fashion...
thanks
fisico30
in case of FET we assume the gate resistance is infinitely high. Thus the current through gate is ideally zero. In fact a field across the oxide layer is set up which determines drain current. Thus the current is dependent on the field which in turn is dependent upon the voltage.
In case of BJT there's a finite amount of base current that flows between the emitter-base junction which also has a voltage drop across is. Thus the base-emitter voltage and the base current are interrelated by a formula. We can say BJT can either be controlled by the base current or the base-emitter voltage.
Holes are not actually a particle. But they do carry charge, which is important enough in electronics.
The transistor works as switch or amplifier, depending on the way you designed the circuit.
In fact the switch operation of transistor is a very crude approximation of an amplifier.
Thanks Kholdstare!
Hello Forum,
I was reading the following explanation about diodes at
http://electronics.howstuffworks.com/led1.htm
It looks like electrons and holes are moving towards each other, like two diffusing gases.
As electrons move from the N type region to the left they automatically form a hole that is filled by an electron that is now moving into it.
On the P type region part of the diode, holes are moving to the right. A hole moving to the right is equivalent to an electron moving to the left, correct?
So, eventually, all electrons are moving to the left, creating a current, which is actually by convention going in the right direction...
Must the doping of the N type need to be the same as the doping of the P type? Does the number of holes in the P type region need to be the same as the number of electrons in the N type region?
If not, why not?
thanks,
fisico30
If the diode is made of a specific material, everytime an electron jumps into a hole light can be emitted (LED), correct?
Does the light emission occur both within the P type and N type or only in some specific region of the combination?
thanks,
fisico30
Related to Are BJT transistors voltage or current controlled?
1. Are BJT transistors voltage or current controlled?
BJT transistors can be controlled by both voltage and current, depending on the specific configuration and use case. In some cases, they may be used as voltage-controlled devices, while in others, they may be used as current-controlled devices.
2. How do BJT transistors work?
BJT transistors work by using a small input current or voltage to control a larger output current. They have three layers of semiconductor material, with the base layer acting as a control element between the emitter and collector layers.
3. What is the difference between a voltage-controlled and current-controlled BJT transistor?
The main difference between a voltage-controlled and current-controlled BJT transistor is the way in which the input signal is applied. In a voltage-controlled transistor, the input signal is a voltage applied to the base, whereas in a current-controlled transistor, the input signal is a current applied to the base.
4. What are the advantages of using BJT transistors?
BJT transistors offer several advantages over other types of transistors, including high current gain, low cost, and easy integration into electronic circuits. They also have fast switching speeds and are capable of handling large currents and voltages.
5. What are some common applications of BJT transistors?
BJT transistors are commonly used in electronic devices, such as amplifiers, switches, and oscillators. They are also used in digital logic circuits, power supplies, and motor control circuits. Additionally, BJT transistors are used in radio and TV receivers, telecommunications equipment, and many other electronic devices.
