- #36
ghwellsjr
- 150
I'm just re-emphasizing what both of you stated early on in this thread:
I think the same thing should apply to avoid confusion with regard to Proper Time. Unlike Coordinate Time which is the same everywhere throughout an IRF, each individual clock can have a different Proper Time on it. We can consistently talk about the Proper Time on each clock at each event and if we care about an elapsed time between two events involving a single clock, then we subtract the two Proper Times at those two events, just like we do for Coordinate Time and we call it something like an elapsed time or a delta time or a time difference or an accumulated time or an amount of aging or something similar but we should not call it simply the Proper Time any more than we would call it the Coordinate Time. But unlike for Coordinate Time, we cannot talk about the delta time between any two events unless there happens to be a clock that is present at those two events and we know its history. And if there are two or more such clocks, then there are two or more delta Proper Times.
Passionflower said:All clocks always record proper time...
... to answer the OP's question:WannabeNewton said:The clocks still measure proper time regardless...
... and in contrast to his statement:nortonian said:You are saying that you can use either proper time or coordinate time depending on where you use it? Is there a convention to know when?
His statement has no meaning apart from an additional specification of the arbitrary history of a clock that spans between those two events, if there is one, which there doesn't have to be.nortonian said:I realize that proper time is measured between two events...
Every tick of every clock can be considered a single event.WannabeNewton said:How would you even make non-trivial sense of proper time for a single event?
You are talking about how to calculate the difference between two Proper Times on a particular clock--a delta Proper Time or a Proper Time interval.WannabeNewton said:Proper time in SR is defined as ##\tau =\int_{\gamma }(-\eta _{ab}u^{a}u^{b})^{1/2}## where ##\gamma## is the worldline of an observer carrying a clock that passes through the two events in between which we are measuring the proper time; different worldlines result in different proper times even if it is between the same two events.
We don't have to start with a frame and describe the worldline of a clock and then calculate the advance of its Proper Time, we can start with a description of the Proper Time and then calculate what the Coordinate Time is for any arbitrary frame.WannabeNewton said:The line integral has to have some pair of endpoints otherwise we are just dealing with sets of measure zero and get nothing useful. The infinitesimal version links nearby events on an observer's worldline.
We often talk about two clocks with a relative speed between them and at the moment of their colocation, we synchronize them. That's a single event concerning the Proper Time on two clocks.WannabeNewton said:Again how would you even make non-trivial sense of proper time for a single event?
To me, this is no different than the terminology we apply to Coordinate Time. If we talk about Coordinate Time, we mean the time that is advancing throughout the reference frame with respect to its origin. If we want to talk about how long it takes for something to get from event A to event B, we don't say that is a Coordinate Time, we say it is a Coordinate Time interval or delta or an elapsed time or something similar.WannabeNewton said:Proper time is an elapsed time whether you are looking at the infinitesimal form or the integrated form.
