Are Equal: $$\sin \alpha_nx - \sinh \alpha_nx$$
  • MHB
  • Thread starter Dustinsfl
In summary, the two equations, $\sin \alpha_nx - \sinh \alpha_nx - \frac{\sin \alpha_n + \sinh \alpha_n}{\cos\alpha_n + \cosh\alpha_n}(\cos \alpha_nx - \cosh \alpha_nx) = \sin \alpha_nx - \sinh \alpha_nx - \frac{\sin \alpha_n - \sinh \alpha_n}{\cos\alpha_n - \cosh\alpha_n}(\cos \alpha_nx - \cosh \alpha_nx)$ and $\sin \alpha_n\cosh \alpha_n = \cos \alpha
Dustinsfl
2,281
\cosh \alpha_nx)
When I plotted them, they were the same but I was only looking at a finite range since I am considering a beam of length 1.
In the range [0,1], they converge at every eigenvalue which are defined by $\sin x\cosh x = \cos x\sinh x$
Mathematics news on Phys.org
\cosh \alpha_nx)
Hi dwsmith, :)
You can show that,
\[\sin \alpha_n\cosh \alpha_n = \cos \alpha_n\sinh \alpha_n\]
\[\Rightarrow\frac{\sin \alpha_n - \sinh \alpha_n}{\cos\alpha_n - \cosh\alpha_n}=\frac{\sin \alpha_n + \sinh \alpha_n}{\cos\alpha_n + \cosh\alpha_n}\]
So both sides are equal provided, \(\sin \alpha_n\cosh \alpha_n = \cos \alpha_n\sinh \alpha_n\).
Kind Regards,
Sudharaka.
FAQ: Are Equal: $$\sin \alpha_nx - \sinh \alpha_nx$$
What is the difference between $\sin \alpha_nx$ and $\sinh \alpha_nx$?
The main difference between $\sin \alpha_nx$ and $\sinh \alpha_nx$ is that the former is a trigonometric function while the latter is a hyperbolic function. This means that they have different mathematical properties and graphs. $\sin \alpha_nx$ represents a sinusoidal wave while $\sinh \alpha_nx$ represents a hyperbolic curve.
How do you solve for the values of $\alpha_n$ in the equation $\sin \alpha_nx - \sinh \alpha_nx = 0$?
To solve for the values of $\alpha_n$ in this equation, you can use algebraic manipulation and trigonometric identities. First, you can factor out $\sin \alpha_nx$ to get $\sin \alpha_nx(1 - \cosh \alpha_nx) = 0$. From here, you can set each factor equal to 0 and solve for $\alpha_n$. This will give you multiple values of $\alpha_n$ that satisfy the equation.
Can $\alpha_n$ be a negative value in the equation $\sin \alpha_nx - \sinh \alpha_nx = 0$?
Yes, $\alpha_n$ can be a negative value in this equation. This is because both $\sin \alpha_nx$ and $\sinh \alpha_nx$ are periodic functions, meaning they repeat values after a certain interval. Therefore, there will be values of $\alpha_n$ (both positive and negative) that will satisfy the equation.
How does the value of $\alpha_n$ affect the graph of $\sin \alpha_nx - \sinh \alpha_nx$?
The value of $\alpha_n$ affects the graph of $\sin \alpha_nx - \sinh \alpha_nx$ by changing the amplitude and period of the function. A larger value of $\alpha_n$ will result in a higher amplitude and a shorter period, while a smaller value of $\alpha_n$ will result in a lower amplitude and a longer period. This can be seen by comparing the graphs of $\sin x - \sinh x$ and $\sin 2x - \sinh 2x$, where the value of $\alpha_n$ is 1 and 2 respectively.
What are some real-world applications of the equation $\sin \alpha_nx - \sinh \alpha_nx = 0$?
The equation $\sin \alpha_nx - \sinh \alpha_nx = 0$ has many real-world applications, particularly in physics and engineering. It can be used to model and analyze wave behavior in various systems, such as sound waves and electromagnetic waves. It can also be used in the design of structures, such as bridges and buildings, to determine the resonance frequencies and avoid potential structural failures. Additionally, it has applications in electronics and circuit analysis, as well as in the study of heat transfer and fluid dynamics.
36K
