renyikouniao
- 41
If a<-1 show that f(x)=ax+cosx and g(x)=ax+sinx are invertible functions;(What are their domain of definitions and ranges?)
MarkFL said:Can you demonstrate that for $a<-1$ both functions are monotonic, thus invertible?
MarkFL said:What condition must hold in order for a function to be monotonic?
MarkFL said:What is true about a function's derivative if it is monotonic?
like using the graph?MarkFL said:Good, yes, this is what is required for strict monotonicity. As long as the derivative has no roots of odd multiplicity, then the function is monotonic.
Can you show then that for $a<-1$ that the derivatives of the two functions will never change sign?
An invertible function is a function where every input has a unique output, and every output has a unique input. This means that the function can be reversed, or inverted, where the outputs become the inputs and vice versa.
A function is invertible if it passes the horizontal line test, meaning that no horizontal line intersects the graph of the function more than once. This ensures that each input has a unique output, making the function reversible.
The inverse of a function is the original function reversed, where the outputs become the inputs and the inputs become the outputs. It is denoted as f-1(x) and is found by switching the x and y values in the original function.
No, not all functions can be inverted. A function must be one-to-one, meaning that each input has a unique output, in order to be inverted. Functions that fail the horizontal line test cannot be inverted.
Some common examples of invertible functions are linear functions, quadratic functions, and trigonometric functions such as sine and cosine. These functions all pass the horizontal line test and have unique inputs and outputs, making them reversible.
