MHB Are local min/max of a cubic function determined by the zeros alone?
Cubic functions' local minima and maxima are not solely determined by their zeros; instead, they depend on the first derivative's roots. While the zeros indicate where the function intersects the x-axis, the first derivative reveals where the function is increasing or decreasing. A root of the first derivative corresponds to an extremum only if the sign changes around that root, which occurs with odd multiplicity. In cases like the function y=x^3, the even multiplicity of the derivative's root results in no extremum at that point. Thus, to accurately identify local extrema, one must analyze the first derivative rather than relying solely on the zeros.
karush
MHB
Just curious are cubic functions dirvel from just having the zeros, does that always determine where the local min/max is. I notice many cubic graphs given on homework show where the zeros are but the local min/max is not given.
For example
$$y=\left(x-4\right)\left(x+1\right)(x+2)={x}^{3}-{x}^{2 }-10x-8$$
$$y'=3{x}^{2 }-2x-10$$
$y'=0$ is $ - 1.5226,2.1893$ and min=-24.1926 max=1.3778
So I presume the local min/max are fixed values given the zeros
Mathematics news on Phys.org
If a cubic function has relative extrema, then they will occur at places where the first derivative has roots. But, at the roots of the first derivative, you won't always find an extremum...consider $y=x^3$.
OK I thought the humps could be moved despite the zeros but doesn't look like it.
So the only to find the extreme is by the derivative
Yes, the first derivative will tell you where the function itself is increasing/decreasing/turning. If the first derivative has differing signs on either side of a root, then you know that root corresponds with an extremum for the function. This will happen for all roots as long as they are all of odd multiplicity.
Observe that in the example I gave of $y=x^3$, the first derivative has a root of even multiplicity, and so its sign does not change as it crosses this first derivative root.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
