- #36
cookiemonster
- 978
"Ask a Stupid Quetion Get a Stupid Answer," lofty physics indeed!
cookiemonster
cookiemonster
Buoyancy is the upward force exerted by a fluid on an object that is partially or completely submerged in the fluid. It is caused by the difference in pressure between the top and bottom of the object.
Buoyancy is calculated by multiplying the density of the fluid by the volume of the displaced fluid and the gravitational acceleration. This is known as Archimedes' principle.
Positive buoyancy occurs when the buoyant force is greater than the weight of the object, causing it to float. Negative buoyancy occurs when the weight of the object is greater than the buoyant force, causing it to sink.
The shape of an object can affect its buoyancy by changing the amount of fluid it displaces. A more streamlined shape will displace less fluid and have less buoyancy, while a more irregular shape will displace more fluid and have more buoyancy.
The buoyancy of an object can be affected by its density, volume, and the density of the fluid it is submerged in. The gravitational acceleration and the shape of the object can also play a role in determining its buoyancy.
