Are my definitions of interior and closure correct?
In summary, the interior A◦ and the closure A¯ of a subset of X are defined as x ∈ A◦ if and only if there exists ε > 0 such that B(x,ε) ⊂ A. The definitions may differ among authors and it is important to refer to your specific text materials for clarification. The terms "neighborhood" and "open set" may be used in the definitions, but if not, there is no need to mention them in this problem. It is best to stick to the definition using open balls if that is what is provided in your text.
Ricster55
39
Define the interior A◦ and the closure A¯ of a subset of X.
Show that x ∈ A◦ if and only if there exists ε > 0 such that B(x,ε) ⊂ A.
[/B]
It would be best not to use abbreviations like "(+) real #" unless your instructor uses such notation.
How things are defined in a metric space can vary from author to author. The fact that you mention "neighborhood" and "open set" makes me wonder if the definitions of "interior of A" and "closure of A" in your text materials might use those terms.
If those two definitions in you text materials don't mention "neighborhood" and "open set" then I see no need to mention them in this particular problem. Does your text define "interior of A" and "closure of A" only using the concept of an open ball ##B(x,\epsilon)## ?
Related to Are my definitions of interior and closure correct?
What is the definition of interior?
The interior of a set is the largest open subset of the set. It includes all points within the set that are not on the boundary.
What is the definition of closure?
The closure of a set is the smallest closed set that contains all the points in the original set. It includes all points in the set as well as its boundary points.
How do you determine the interior of a set?
To determine the interior of a set, you can either visualize the set and identify the largest open subset, or use the mathematical definition of the interior as the set of all points that do not lie on the boundary.
How is the closure of a set different from its interior?
The closure of a set includes both the set and its boundary points, while the interior only includes the points that are not on the boundary. The closure is also the smallest closed set that contains all the points in the original set, while the interior is the largest open subset of the set.
Why is understanding interior and closure important in mathematics?
Understanding interior and closure is important in mathematics because it allows us to define and analyze concepts such as continuity, compactness, and convergence. It also helps us to distinguish between different types of sets and understand their properties.
  • Differential Geometry
