Are P and E fields in LIH dielectric in dynamic equilibrium
In summary: In this case, the polarization of the dielectric is a function of the applied field, and can be determined from it.
sigma_
34
If we know that the Polarization P in LIH dielectrics is proportional to the net field inside the dielectric according to:
P = ε0χeE...(1)
And we know that
D = εE...(2)
Does it not follow that we can ascertain the polarization directly from the applied (free charge) field, since we can relate D to E, and then E to P?
The author of my electrodynamics text (Griffiths), says that we cannot. His explanation being that once we place dielectric in an external field E0, the material will polarize and create an opposing field to the applied field, which in turn modifies the polarization again because it changes the total field that the atoms/molecules in the material are being subject to, and this process repeats over and over. In actuality, are these two quantities (E and P) in some sort of dynamic equilibrium within the material? If so, how come (1) and (2) are valid?
sigma_ said:
...In actuality, are these two quantities (E and P) in some sort of dynamic equilibrium within the material?...
Yes, only the equilibrium is more appropriately called static (##\mathbf E##,##\mathbf P## are do not change in time).
They both state the same thing: the polarization ##\mathbf P## is proportional to ##\mathbf E##.
You seem to think that ##\mathbf D## is somehow simply related to applied field ##\mathbf E_0##. In general, it is not! ##\mathbf D## is defined by
\mathbf D = \epsilon_0 \mathbf E + \mathbf P,
which contains both ##\mathbf E, \mathbf P##, the "quantities in mutual equilibrium". There is no simple relation of ##\mathbf D## to ##\mathbf E_0##, except inside a parallel plate capacitor, where ##\mathbf D = \epsilon_0 \mathbf E_0##.
Thanks for the reply, Jano!
We also know, however, that
∫D.dA = Qfenc
so D has to somehow be related to the applied field, because it is the flux density of the free charge, and typically free charge is what we control, and create (apply) fields with.
I think maybe my interpretation of D is incorrect here then?
Both ##\mathbf D## and ##\mathbf E_0## due to free charges satisfy the same equation you wrote above, but that is not sufficient to establish simple relation between them. This is because it is just one equation and we deal with vectors, which have three components. The two quantities are different from each other by third vector field that has every surface integral zero. Such field is called solenoidal field, and can be very complicated. It will be determined by the arrangement of the free charges with density ##\rho_{free}## and the dielectric bodies. ##\mathbf D ## at all points of the system can be found out from ##\rho_{free}##, but knowledge of ##\mathbf E_0## won't help much; I think one would do better with some energy minimization method that takes into account the spatial dependence of ##\epsilon##.
So in the scenario I listed above, ##\mathbf D## and ##\mathbf E_0## are interchangable as long as a factor of ##\epsilon## is accounted for?
What do you mean by "interchangeable" ? They are not in simple relation one to another. What is your scenario concretely?
Let's say, for instance, an LIH dielectric between the plates of a parallel plate capacitor.
In parallel plate capacitor, ##\mathbf D = \epsilon_0 \mathbf E_0## where ##\mathbf E_0## is the field due to free charges. The factor ##\epsilon_0## is permittivity of vacuum, not of the dielectric.
Likes 1 person
Thank you very much for your help!
Related to Are P and E fields in LIH dielectric in dynamic equilibrium
1. What is a dielectric?
A dielectric is a material that can be polarized by an electric field, meaning its molecules will align in a specific direction when exposed to an electric field. This polarization creates an electric displacement field, which can interact with the electric field to change its strength and direction.
2. What is dynamic equilibrium?
Dynamic equilibrium refers to a state in which opposing forces or processes are balanced and there is no net change. In the context of P and E fields in a dielectric material, it means that the electric displacement and electric field are in balance and there is no overall change in the system.
3. How do P and E fields interact in a dielectric material?
When an electric field is applied to a dielectric material, it causes the molecules to polarize, creating an electric displacement field. This displacement field interacts with the electric field, causing a change in its strength and direction. This interaction is what allows dielectric materials to store energy and influence the behavior of electric fields.
4. What is LIH?
LIH stands for linear isotropic homogeneous, which describes the properties of a dielectric material. Linear means that the material's response to an electric field is proportional to the strength of the field. Isotropic means that the material's properties are the same in all directions. Homogeneous means that the material has the same properties throughout its volume.
5. How does the equilibrium of P and E fields in a LIH dielectric material affect its properties?
The dynamic equilibrium of P and E fields in a LIH dielectric material is what allows it to store energy and influence the behavior of electric fields. This makes it useful in various applications, such as capacitors, insulators, and dielectric resonators. Additionally, the properties of a LIH dielectric material can be manipulated by changing the strength and direction of the electric field applied to it, making it a versatile material in scientific research and technological advancements.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
