Are photons the wave sources of Huygens-Fresnel principle?
In summary, Huygens-Fresnel principle states that every point in a light wave is itself a wave source. photons have a wavelength, they are QM objects.
DoobleD
259
1 - Huygens-Fresnel principle states that every point in a light wave is itself a wave source,
2 - light is made of photons,
3 - photons have a wavelength, they are QM objects.
Hence my question : are photons the actual wave sources in Huygens-Fresnel principle ? Or are those two interpretations totally different things ?
Likes member659127
They are completely different things.
Thank you for answering. Is there a physical explanation for the wave sources of Huygens-Fresnel principle ? I think I read once it had something to do with QM ?
Historically yes, totally different things, but the modern view in the context of quantum electrodynamics or qft two pictures are not completely irrelevant I would argue, since the "photon" is explained in terms of the field.
Edit: good question by the way
But a photon is not a point source and is not of defined size.
In addition, we know that Huyghens gives the right answer, but is it for the correct reason? We only see diffractiion where there is an obstruction i.e. charges. Maybe radiation from the currents on the diffracting object give the same result?
For mechanical waves, yes! Absolutely... Just imagine every point of the wavefront of a water wave trying to "push down" and acting like a point source... Similar sort of argument can also worked out for EM waves like the "local" disturbance in the EM field. And since QFT is based on fields I believe the two pictures are not totally irrelevant...
On the fundamental level the sources of the electromagnetic field are electric charges and magnetic moments of the elementary particles (quantum fields). Since electromagnetic theory is an Abelian gauge theory the photons themselves are uncharged and thus not sources of the electromagnetic field.
Hyugens principle is one of the family of mathematical theorems that allow the "change of basis".
An example is Fourier transform that allows any periodic function to be re-expressed as weighted sum of sines.
Another example is Taylor series that allows any smooth function to be re-expressed as weighted sum of polynomials.
A very simple example is a change of basis of a vector space. You can take any linearly independent set of vectors and then for any vector you can re-express it as a weighted sum of such vectors.
There are many more such theorems.
Hyugens principle is of similar kind. It says that any function satisfying a wave equation may be re-expressed as weighted sum of spherical waves originating at every point of space.
So yes, photons in quantum dynamics do support such reexpression, so they satisfy Hyugens principle.
Moreso, this is exatly the rationale behind the Feynman quantization, with an important constraint. Feynman said that any quantum field may be re-expressed as a weighted sum of a special basis of fields, where every field has the same amplitude and they differ only in phase.
To say it once again:
You want to have a certain sophisticated field of unit amplitude and some phase.
You select a basis of simple fields, each originating at every point of space, which have unit amplitude and zero phase (by some convention).
You can modify the above fields by changing their amplitude or shifting their phase, and you can sum them up.
It turns out that you don't need to change their amplitude to derive any field you need. You only need to shift their phases. Quantum field theory can pass under this important restriction.
Once more, photons (or any other quantum field) satisfy the Hyugens principle and this is an important fact.
Likes kurt101 and member659127
Huygens's principle is a heuristic principle, guiding you to find an ansatz to solve wave equations under certain conditions (e.g., the problem of refraction on openings, lits or gratings etc.). It's in some approximative sense quite well satisfied for electrodynamics in 3 spatial dimensions (Kirchhoff's approximation). It's not at all valid for 2D wave problems.
The much more precise and powerful mathematical concept is that of Green's functions of the corresponding linear differential operators relevant for the equation in question. For the wave equation the paradigmatic example is the d'Alembert operator ##\Box=1/c^2 \partial_t^2-\vec{\nabla}^2##.
FAQ: Are photons the wave sources of Huygens-Fresnel principle?
1. What is the Huygens-Fresnel principle?
The Huygens-Fresnel principle is a theory in optics that explains how light propagates as a wave. It states that every point on a wave front can be considered as a source of secondary waves, and the sum of these secondary waves determines the shape and behavior of the overall wave.
2. Are photons the only wave sources of the Huygens-Fresnel principle?
No, photons are not the only wave sources of the Huygens-Fresnel principle. The principle applies to all types of waves, including electromagnetic waves like light. Photons are particles that make up the electromagnetic wave and are not considered as wave sources in this principle.
3. How does the Huygens-Fresnel principle explain diffraction and interference?
The Huygens-Fresnel principle explains diffraction and interference by considering each point on a wave front as a source of secondary waves. As these secondary waves interact and interfere with each other, they create patterns of constructive and destructive interference, resulting in the diffraction and interference effects observed in waves.
4. What is the significance of the Huygens-Fresnel principle in modern optics?
The Huygens-Fresnel principle is still a fundamental concept in modern optics and is used to understand and predict the behavior of light in various optical systems. It also forms the basis of many advanced optical techniques, such as holography and Fourier optics.
5. Are there any limitations to the Huygens-Fresnel principle?
Yes, there are limitations to the Huygens-Fresnel principle. It is a simplified model that does not take into account factors such as wavelength and the size of the wave front. It is also based on classical physics and does not fully explain the behavior of light at the quantum level. However, it remains a useful tool for understanding and analyzing many optical phenomena.
