Are singularities part of the manifold?
In summary: CMBR everyone in the universe, any family of observers must agree about).This is not correct; the expansion of the congruence of "comoving" observers in FRW spacetime is independent of coordinates and independent of any choice of simultaneity convention.
TrickyDicky
3,507
27
Mod note: Posts split off from https://www.physicsforums.com/showthread.php?p=4468795
WannabeNewton said:
Dun dun duuuun :)
Hi, WN, might the OP be referring to GR instead of SR, more specifically to the expanding FRW universe in which it is impossible to even consider the notion of exansion without agreeing about an "everywhere at once" notion?, after all the current opinion in physics is that our universe is globally described by GR (which implies locally by SR of course) rather than by Minkowski flat spacetime where relativity of simultaneity truly belongs.
He might be, but so what? The answer is the same either way: "at the same time" is observer-dependent.
You mean expansion is observer-dependent?
I mean if you apply the relativity of simultaneity strictly to extended objects like the universe there is no possible BB model.
sb635 said:
If you examine Einstein's Equivalence Principle, it shows what Einstein was talking about... something physically, absolutely moved in Einstein's "external world.
Einstein's equivalence principle is about acceleration not motion; you'd have to replace the word "moved" with "accelerated" to make what you said above correct.
For the FLRW universes, everything is described in terms of the observers comoving with the Hubble flow. The global simultaneity slices are with respect to the congruence defined by these observers so again the global simultaneity is only for said family of observers. A different family of observers in the same space-time that define a congruence with non-vanishing twist won't even have global simultaneity slices.
Certainly, but the relativity of simultaneity argument you guys are using to answer the OP forbids the existence of such family of observers when strictly applied (and even more something physical like a last scattering surface and the CMBR everyone in the universe, any family of observers must agree about). This was my point when making the distinction SR/GR.
That family of observers is free to define congruences as they see fit, but the mainstream theory says they should still observe the CMB and be able to relate the doppler shift they observe it with to the family of observers that define global simultaneity slices (global "now instants") and that allow the notion of a homogeneous universe at each instant and a density change with respect to those instants (spatial expansion).
There is no absolute simultaneity implied by GR either. You can take the FLRW spacetime, do a coordinate transform with a different global simultaneity convention, and still be able to correctly describe all physics. The GR vs SR distinction doesn't make a difference here. Simultaneity is relative either way.
DaleSpam: If you're referring to my post, I agree with you completely on the relativity of simultaneity. My qualifier was on my statement that there always exists a global synchronization procedure. I don't feel comfortable generalizing this to GR (does it simply depend on whether the manifold admits a global coordinate system?).
You woul need to define what you mean by "absolute" here, I don't think it is a scientific term.
Also I'm not sure what you mean by a coordinate transformation with global simultaneity convention, what global convention? you surely know there is no global coordinates in GR.
And exactly relative to what, is the simultaneity of the CMB?
TrickyDicky said:
the expanding FRW universe in which it is impossible to even consider the notion of expansion without agreeing about an "everywhere at once" notion?
No. See above.
Sure there is; the spacetime geometry described by the BB model is independent of coordinates and independent of any choice of simultaneity convention, just like any spacetime geometry in GR.
No, it doesn't. The "last scattering" surface is independent of coordinates and independent of any choice of simultaneity convention. So is the CMBR.
What you should be saying is that there is only one set of coordinates and one simultaneity convention in which the last scattering surface is a surface of constant coordinate time, and in which the isotropy of the CMBR is manifest in the coordinates. But that statement doesn't justify the other claims you're making.
And all of this is indeed what such a family of observers will be able to do. Why do you think it wouldn't be?
You are correct. By "absolute simultaneity" I simply mean the converse of "relative simultaneity" where simultaneity is a matter of convention and different conventions lead to different notions of simultaneity.
That isn't true, in general. Many space times do admit global coordinates. However, to make my statement applicable to general space times you can weaken it to "non-local" rather than "global".
The CMB doesn't have an intrinsic simultaneity. You will have to explain what you mean by simultaneity of the CMB.
Peter, you are making Exactly the same point I am, I don't know how you manage to make it look like you are arguing with me. ;)
No, not in general, I said in GR so I was referring to curved spacetimes.
Sure I mean the relativity of simultaneity of observers very far apart but at rest with the CMB.
Because it seems like you're saying the opposite. This has happened before. :wink:
It seems to me that you are making opposing points.
Relativity of simultaneity according to what simultaneity convention? Remember that the global simultaneity convention of the "comoving" FRW chart (in which each surface of constant coordinate time is a surface of simultaneity for each "comoving" observer) "lines up" with the local simultaneity convention of each "comoving" observer--i.e., within the local inertial frame of each "comoving" observer, events which are simultaneous with respect to the global FRW coordinates are also simultaneous with respect to the LIF.
Me too, specifically I was referring to the FLRW spacetime.
The FLRW spacetime admits a traditional coordinate chart which defines the simultaneity convention you are focused on, but it also admits many other coordinate charts. The notion of simultaneity defined by those alternate coordinate charts is every bit as "global" as the notion of simultaneity on the traditional chart, although they disagree. All of the physics of the FLRW chart is the same regardless of the simultaneity convention adopted. Therefore, simultaneity is relative in the FLRW spacetime also, the CMB notwithstanding.
My only point has been that relativity of simultaneity is a local notion, how is this making opposing points?
I guess we are referring to different things when talking about global coordinates, I mean the standard sense in which global means covering the whole manifold. I'm sure now you will agree with me. ;-)
Again there seems to be some confusión here about what are global coordinates, FRW coordinates are not global in the same sense Minkowski coordinates are in Minkowski spacetime, and this is key to understand the difference between a local and a global simultaneity convention.
In any spacetime which admits a global chart (standard sense) you can do a coordinate transform to obtain a different global chart with a different notion of simultaneity. So no, I don't agree with you. Simultaneity is relative in GR also including curved spacetimes. Relativity of simultaneity is not merely a local concept.
To be sure, you are saying you consider FRW coordinates global in the same sense cartesian coordinates are in Euclidean space?
I don't understand what you're saying here. FRW coordinates cover the entire spacetime, just as Minkowski coordinates do, and that's the sense of "global" you said you were using.
I didn't say that. I think that the answer to that depends on the topology of the universe.
What I am saying is that simultaneity is relative, regardless of whether you are talking about SR or GR.
DaleSpam said:
I didn't say that.
Good, then we are agreeing on that. :wink:
And you'd have to quote me saying that simultaneity is not relative. Locally in GR and globally in SR.
In what sense is global simultaneity not relative? Two different time-like congruences in the same space-time don't necessarily pick out the same one-parameter family of orthogonal hypersurfaces foliating the space-time (assuming that such families actually exist for the two congruences). In other words, the global simultaneity slices of two different families of observers in a given space-time (assuming such slices can actually be defined) need not agree.
Mate, I just invited anyone to quote me saying simultaneity is not relative, I never wrote such thing, I merely made a distinction between the concept in GR and SR, it is local in the former and global in the latter but in both simultaneity is relative. Is my english that bad or what?
Yes. At least three of us got a different impression from your posts. Specifically, this quote makes it seem like you believe relativity of simultaneity does not belong in GR:
TrickyDicky said:
our universe is globally described by GR ... rather than by Minkowski flat spacetime where relativity of simultaneity truly belongs.
In any case, the relativity of simultaneity is not merely local in GR.
DaleSpam said:
Yes.
Yes to my bad english?!:cry:
Fine, then, we all know this things are democratic so yes I wrote somewhere in the thread "simultaneity is not relative".
Make it seem is opinable, Simultaneity of relativity is an SR concpt historically and from any point of view you might want to choose. It so happens that GR is locally Minkowskian and that makes it part of GR.
This sounds as if it made you mad :mad: that SR is merely local in GR. But if it were global it would be SR not GR don't you think? :rolleyes: :wink:
  • #31
It looks to me like everyone is using different definitions of "simultaneity" and "relativity of simultaneity". Maybe we should taboo those terms in this thread, so that everyone has to explicitly define what they mean by them.
  • #32
No, I disagree. If you have a global coordinate chart in GR it doesn't suddenly become SR.
  • #33
Er...there are no global coordinates (defined as it is standard as those that cover the whole manifold) in curved manifolds, it is one of the most basic facts of differential geometry.
  • #34
No, you're thinking of global inertial frames. There's a difference. As an example, Kruskal coordinates for the Schwarzschild space-time cover the entire manifold.
  • #35
You're kidding, right? Some examples of coordinates on curved manifolds that cover the entire manifold:
Kruskal coordinates on maximally extended Schwarzschild spacetime;
FRW coordinates on FRW spacetime (I asked you before about this--are you claiming that FRW coordinates do *not* cover all of FRW spacetime? If so, please show me, explicitly, what part of FRW spacetime FRW coordinates do not cover.)
Any of several standard charts on de Sitter spacetime (any of the ones mentioned in the Wikipedia page would work).
And, of course, a Penrose chart on *any* of the spacetimes I mentioned; Penrose charts are specifically constructed to make sure they cover the entire manifold--and what's more, they do so with a finite range of all coordinates.
26K
