I Are spherical transverse waves exact solutions to Maxwell's equations?
The discussion centers on the claim from a NASA paper that spherical transverse waves are solutions to Maxwell's equations in the limit as kr approaches infinity. It highlights the divergence and curl of the electric field, noting that certain terms do not vanish unless r approaches infinity. The conversation questions whether this implies that spherical waves are not exact solutions in a vacuum, despite the paper considering a homogeneous medium. It concludes that spherical waves are indeed approximate solutions, relying on specific assumptions such as r' being much smaller than r and kr being much greater than one. Overall, the findings suggest that while spherical waves can be treated as solutions under certain conditions, they require careful consideration of their limitations.
Delta2
Insights Author
TL;DR Summary
Spherical waves as solutions to Maxwell's equations in vacuum.
In this paper in NASA
https://www.giss.nasa.gov/staff/mmishchenko/publications/2004_kluwer_mishchenko.pdf
it claims (at page 38) that the defined spherical waves (12.4,12.5) are solutions of Maxwell's equations in the limit ##kr\to\infty##. I tried to work out the divergence and curl of ##\vec{E(r,t)}## and find out that for example the divergence of E contains a term $$\frac{e^{ikr}}{r}\nabla\cdot\vec{E_1(\hat r)}$$, which doesn't seem to vanish (given the extra conditions (12.6-12.9) unless of course we take the limit ##r\to\infty##.
Is it that what it means at first place when it says that these waves are solutions in the limit ##kr\to\infty##? Does this means that spherical waves are not exact solutions to Maxwell's equations in vacuum? (the paper considers the general case of a homogeneous medium present but vacuum is a special case of a homogeneous medium isn't it?)
P.S ##\vec{E_1(\hat r)}## cannot be a constant vector as that is implied by 12.6, that is it is always perpendicular to ##\hat r##.
P.S2 I find no easy way to prove that ##\nabla\cdot\vec{E_1}=0## from the 12.6-12.9 conditions
P.S3 I think I got it now. The authors of the paper say that ##\vec{E_1}## (and ##\vec{H_1}##) must not depend on r. If so then their divergence and curl have ##\frac{1}{r}## dependence which together with the other ##\frac{1}{r}## from the term ##\frac{e^{ikr}}{r}## make a term ##\frac{1}{r^2 }##which can safely be neglected for ##r\to\infty##.
Spherical waves are approximate solutions to Maxwell's equations. You have to make approximations based on the assumptions $r'<<r$ and kr>>1.
Likes vanhees71 and Delta2
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
