Are the axes of celestial objects parallel in a galaxy?
In summary: Galaxies have similar orientations to stars within them, but there is no overall trend across different galaxies.
lw1990
Speaking only of approximately spherical moons, planets, and stars (not asteroids), which rotate about their axis, are the axes all pointed approximately the same direction?
Is it true for moons and their parent planet?
Is it true for planets and their parent star (solar system)?
Is it true for stars and their galactic core?
Is it true for galaxy vs galaxy? Are they oriented in approximately the same axis?
Astronomy news on Phys.org
It's only approximately true for planets in a solar system and moons around planets - but there's plenty exceptions, even just in our solar system (most notably Uranus).
Otherwise it's random. (e.g., solar system's angular momentum axis is 'tilted' ~60 degrees off the plane of rotation of the Milky Way; similarly, there's no pattern in observed exo-systems)
The reason for approximate alignment in the first two cases is due to how bodies in a stellar system generally coalesce from one large molecular cloud spinning roughly in the same plane (due to the dynamics of collapsing gas clouds).
However, there's plenty of 'chances' for bodies formed this way to be later kicked out of this alignment. Collisions, orbital capture, orbital ejections - all act to randomise movement patterns.
On larger scales, the difference between the radius of rotation of a system (such as a galaxy, or a group of galaxies) as compared with the size of the area undergoing collapse to form a rotating object is too large to have any effect - in a similar way to how the Coriolis force can cause continent-spanning cyclones to rotate in a preferred direction depending on which hemisphere it occurs on, but it doesn't matter for the direction of water draining in your sink whether you're in Alaska or Australia (because local interactions dominate the evolution of the system).
Likes Hoophy
have you ever looks at a deep sky image of many galaxies ? maybe not, as if you had, you wouldn't have asked that question :wink:
have a look at this pic and see what you think ...
at all sorts of anglesDave
Even within the solar system planets and other objects are not all orientated in similar ways.
Planets don't orbit the sun in exactly the same plane, only approximately so.
(and the orbital plane of Pluto, technically a dwarf planet nowadays, but still a substantial object, is way out compared to the main planet orbits.)
Polar orientation in relation to it's orbital plane differs widely between planets, Earth has tilt 23 degress and Uranus is an extreme case of 98 degrees, so its spinning sideways in relation to it's orbit.
Venus for some reason unknown rotates backwards as compared with other planets, (best guess is that it's even more extremely tilted than Uranus, effectively it has been turned upside down by past gravitational interactions.)
Likes Hoophy
Related to Are the axes of celestial objects parallel in a galaxy?
1. Are the axes of celestial objects always parallel in a galaxy?
No, the axes of celestial objects in a galaxy are not always parallel. This is because the orientation of celestial objects can be influenced by a variety of factors, such as gravitational interactions with other objects in the galaxy and the overall structure and dynamics of the galaxy itself.
2. How do we determine the orientation of celestial objects in a galaxy?
We can determine the orientation of celestial objects in a galaxy by studying their movements and positions relative to other objects in the galaxy. This can be done through observations using telescopes and other instruments, as well as through computer simulations and mathematical models.
3. Can the orientation of celestial objects change over time in a galaxy?
Yes, the orientation of celestial objects in a galaxy can change over time. This is due to the constantly evolving nature of galaxies, which can cause changes in their gravitational fields and other factors that can affect the orientation of celestial objects within them.
4. Are there any patterns or trends in the orientation of celestial objects in galaxies?
Yes, there are some patterns and trends in the orientation of celestial objects in galaxies. For example, in spiral galaxies, the orientation of their spiral arms tends to follow a similar pattern, and in some cases, the orientation of these arms can be influenced by the central supermassive black hole.
5. How does the orientation of celestial objects in a galaxy affect its overall structure and dynamics?
The orientation of celestial objects in a galaxy can have a significant impact on its structure and dynamics. For example, the orientation of a galaxy's disk can affect the shape of its spiral arms, and the orientation of its central bar can influence the overall shape and rotation of the galaxy. Additionally, the orientation of celestial objects can also play a role in the formation of new stars and the evolution of the galaxy as a whole.
