Are the Battery Capacity Calculations for Electric Vehicles Correct?
  • Thread starter Thread starter PhysicsTest
    Current
The discussion focuses on the calculations for battery capacity in electric vehicles, emphasizing that battery capacity is defined in ampere-hours (AH), not just amps. The formula for battery capacity is clarified as Battery Capacity = Current * Time, with AH representing the total charge available. The relationship between coulombs and ampere-hours is explained, highlighting that 1 AH equals 1 amp over one hour. The conversation also touches on the definition of the coulomb in relation to amperes and seconds. Overall, the calculations and definitions provided support the understanding of battery capacity in electric vehicles.
PhysicsTest
If an electric vehicle needs to provide 400HP for 1 hour and the vehicles battery voltage is nominally 300V, what is the absolute minimum rating of the battery capacity in Amp-Hours (1HP = 750 W)
Capacity = Current * Discharge Time
Power = 400 * 750 = 300000 Watts
V*I = 300000
I = 300000/300 = 1000 Amps
Battery Capacity = 1000 * 1 = 1000AH. Are the calculations correct? Why the battery capacity is defined in Amps?
It seems OK.
Not Amps but AH with V given as you got it.
Likes PhysicsTest
AH (Amp-hours) is a measure of charge. 1AH=1A*3600s=3600 Joules.Coulombs.
Likes DaveE and PhysicsTest
The battery capacity is defined in A.h or ampere-hour.
Just like a water tank accumulates volume in gallons (ready to flow out), a battery accumulates charge in coulombs (ready to flow out as well).
Please, see:
https://en.wikipedia.org/wiki/Coulomb
https://en.wikipedia.org/wiki/Ampere-hour
"The SI defines the coulomb in terms of the ampere and second:
1 C = 1 A × 1 s.
The ampere is defined by taking the fixed numerical value of the elementary charge e to be 1.602176634×10−19 coulombs."
Likes PhysicsTest
Coulombs, surely. Or, equivalently, Joules per Volt.
