Are the electrons in TV set wave or particle?
In summary: It might help at this point if someone (who isn't me) explains how macroscopic objects (such as cats and humans) have wave functions and wave-like properties.Yes, please do.
feynmann
156
The interpretation of Quantum mechanics wavefunction indicates that it can only predict the probability where the electrons might be. So the next positions will be totally random.
But the positions of electrons in TV set seem to be pretty predictable, otherwise the screen won't show a good picture
Electrons are particles, but all moving particles behave like waves, with wavelength = h/momentum.
Electrons in a TV are moving fast enough that you have to take into account relativity but the wavelength is still roughly = h/mv.
Since h (Plank's constant) is very small = 6.626 ×10−34 Js the wavelength isn't very large and the electron appears as a sharp point.
The fact that the wavelength is so small is why electron microscopes can see much smaller detail than optical ones.
The position error is microscopic in scale, not macroscopic.
Where is the boundary between microscopic and macroscopic?
There is no boundary; it is a continuum.
All objects, from planets down to electrons are both waves and particles at all times.
Planets behave A LOT like particles (easy to know where they are and how fast they're moving); while their wave properties are jumbled together.
This is the crux of Schrodinger's Cat. In principle an object the size of a cat can be treated as a wave, or can be seen in superposition (just like particles can), but in practice, you're dealing with the wave functions of uncountable particles; they will collapse into one cat.
To make an analogy with light: an unobstructed laser beam follows basically a classical trajectory, but if you put a narrow slit in front of it, you get a diffraction pattern. Looking at the original beam more closely, if you let it propagate a long distance, it spreads because of diffraction at the aperture of the laser.
Similarly, in undergraduate physics labs, a common experiment is to take a narrow beam of electrons (comparable to the ones produced in a CRT), send it through a crystal (lots of narrow "slits") and observe the diffraction/interference pattern. Without the crystal, you get just a small spot on the viewing screen. Over long distances, in principle you'd get effects from diffraction at the aperture of the electron gun, but in practice the electrons repel each other which usually has a larger effect on the spreading of the beam.
Right but let's not mislead the OP into thinking that these beams of light "change" from one form to another. Light, and everything else is both particle and wave simultaneously. It's just a matter of how you look at it.
The question is similar to
At what speed does an accelerating object switch from Newtonian acceleration to relativistic acceleration?
The answer, of course, is: there is no switch. When you are walking down the street, you are obeying relativistic laws it's just vanishingly small.
FAQ: Are the electrons in TV set wave or particle?
What is the nature of electrons in a TV set?
The nature of electrons in a TV set is that they exhibit properties of both waves and particles. This concept is known as wave-particle duality, which states that particles such as electrons can exhibit both wave-like and particle-like behaviors depending on the situation.
How do electrons behave in a TV set?
In a TV set, electrons behave like particles when they are accelerated and collide with the screen, creating the images we see. However, they also exhibit wave-like behavior when passing through the electron gun and the cathode ray tube in the TV set.
Can electrons in a TV set be described as waves?
Yes, electrons in a TV set can be described as waves. This is because they have a wavelength and frequency, which are characteristics of waves. Additionally, their behavior in the TV set can be explained using wave equations and principles.
Do electrons in a TV set always behave as waves and particles simultaneously?
Yes, electrons in a TV set always exhibit both wave-like and particle-like behaviors simultaneously. This is a fundamental concept in quantum mechanics and has been proven through various experiments and observations.
What impact does the wave-particle duality of electrons have on TV technology?
The wave-particle duality of electrons has a significant impact on TV technology. It allows for the creation of images on the screen through the manipulation of electron waves, while also allowing for the precise control of particles for the formation of these images. Without this duality, TV technology as we know it would not be possible.
