Are the energy fluctuations in space real or virtual?
In summary, the uncertainty principle states that there is a minimum limit to how precisely we can know the position and momentum of a quantum object. This can be related to the uncertainty in energy, which can lead to discussions about energy fluctuations in otherwise empty space. However, this concept is often misunderstood and should not be applied to real systems with size. Instead, it is a virtual construct that does not have any real effects or cause space expansion. The idea of energy in empty space is a common misconception and can only be fully understood by studying Quantum Field Theory in textbooks. The Casimir Effect, often used as evidence for energy in empty space, is not actually related to vacuum fluctuations.
jcap
170
Heisenberg's uncertainty relation says:
$$\Delta x \Delta p \ge \hbar$$
If we assume a massless quantum object then we have the relationship ##\Delta E = c\Delta p## so that the above uncertainty relationship becomes
$$\Delta E \ge \frac{\hbar c}{\Delta x}.\tag{1}$$
I understand that if we have a real system with size ##\Delta x## then there is necessarily an uncertainty in the real energy, ##\Delta E##, given by Equation(1).
But this relationship is commonly applied to otherwise empty space in order to argue that there is a fluctuation of energy ##\Delta E## in each interval of space ##\Delta x##. As we take ##\Delta x## to be arbitrarily small then ##\Delta E## becomes arbitrarily big. If we apply a cutoff at the Planck scale then general relativity implies that space should expand exponentially at an enormous rate which is not observed (the cosmological constant problem).
But surely in the analysis regarding empty space there is no real object with size ##\Delta x## and therefore no real energy fluctuation ##\Delta E##?
Instead it seems to me that the arbitrary interval of space of size ##\Delta x## is a virtual construct so that by the uncertainty principle it should only lead to a virtual energy fluctuation ##\Delta E##.
Surely such a virtual energy fluctuation cannot be expected to lead to any real effects like exponential space expansion?
P.S. However I could imagine differences in virtual energy leading to real effects.
I would ask what is confining it in the first place.
The energy of empty space is zero by a process called Normal Ordering:
https://en.wikipedia.org/wiki/Normal_order
Forget what you read in popularization's - you can only find out about Quantum Field Theory by reading decent textbooks on it.
That empty space has energy is a very common but incorrect misconception.
Please, do not post this or that link that says otherwise. They are wrong - or rather sometimes physicists speak loosely.
If you want to argue it, mods like me will keep a careful eye on it to ensure it doesn't develop into a long thread along the lines of - but so and so says - yes but he is speaking loosely - its actually zero. Such threads really don't go anywhere and are just long meandering reads of no actual value.
And to ensure you don't bring up the Casmir Effect, be aware it's explanation does not involve vacuum fluctuations:
https://arxiv.org/abs/1605.04143
https://arxiv.org/abs/hep-th/0503158v1
Thanks
Bill
Likes Demystifier
Related to Are the energy fluctuations in space real or virtual?
1. What are energy fluctuations in space?
Energy fluctuations in space refer to the constant changes in the amount of energy present in a specific region of space. This can be caused by various factors, such as the presence of matter and radiation, quantum fluctuations, and the expansion of the universe.
2. Are energy fluctuations in space real or virtual?
The answer to this question is both. Energy fluctuations in space can be considered as real, as they have observable effects and can be measured. However, they can also be considered as virtual, as they are a result of the uncertainty principle in quantum mechanics and do not have a permanent existence.
3. How do energy fluctuations in space affect the universe?
Energy fluctuations in space play a crucial role in the evolution of the universe. They can cause small variations in the density of matter, which can lead to the formation of galaxies and other structures. These fluctuations also contribute to the expansion of the universe and the overall energy balance.
4. Can energy fluctuations in space be harnessed for energy production?
Currently, there is no known way to harness energy fluctuations in space for practical energy production. However, there have been some theories proposed, such as using the Casimir effect, which involves manipulating virtual particles to generate usable energy. Research is ongoing in this area, but it is still in its early stages.
5. Are energy fluctuations in space constant or do they vary?
Energy fluctuations in space are not constant and can vary in both magnitude and frequency. These fluctuations are affected by various factors, such as the presence of matter and radiation, the expansion of the universe, and the laws of quantum mechanics. Therefore, they are constantly changing and can be unpredictable over time.
  • Quantum Physics
  • Quantum Physics
