Are the following subsets open in the standard topology?
In summary: And not by definition for open sets in ##\mathbb{R}^n##, in which the OP is working. In that case, it actually needs a proof.
sa1988
222
23
Determine whether the following subsets are open in the standard topology:
a) ##(0,1)##
b) ##[0,1)##
c) ##(0,\infty)##
d) ##\{x \in (0,1) : \forall n \in \mathbb{Z}^{+}## ##, x \not= \frac{1}{n}\} ##
a) ##(0,1)## is open because for any ##x## in the given interval ## 0 < x < 1 ##, it always has reachable neighbourhoods without any boundary.
b) ##[0,1)## is not open because the point ##x=0## has neighbourhoods outside the set. The set is also not closed because its complement gives ##(-\infty , 0]## and ##(1,\infty )## where the former is not open for similar reasoning.
c) ##(0,\infty)## is open, because all values ##x## in ##0 < x < \infty ## have neighbourhoods, similar to part a).
d) ##\{x \in (0,1) : \forall n \in \mathbb{Z}^{+}## ##, x \not= \frac{1}{n}\} ## is not open because there are discontinuities every time one reaches a point ##\frac{1}{n}##. For this reason the set is also not closed, because the complement will leave 'opposite' discontinuities.As with my previous thread on basic set questions, I'm hoping I've got these right but am running it by the forum because Topology and set theory in general is still currently fairly new territory for me.
Many thanks.
You may want to reconsider (d).
Ask yourself if for any given ##x## in the specified set there exists a neighbourhood that is within the set.
Likes sa1988
Hmm, I think I know what you mean.
The set has all ##\frac{1}{n}## removed, but it's possible to get infinitely close to that 1/n without ever reaching it, i.e. the point at ## \frac{1}{n} - \frac{1}{9999999...}##
So the discontinuities are there, but the 'limit' is unreachable. All ##x## in the set have neighbourhoods. Thus the set is open.
I would then say that the set is still not closed, because its complement gives only the specific values ##\frac{1}{n}##, none of which have neighbourhoods.
Right. Alternatively, the set can be written as
\bigcup_{n=1}^\infty \left(\frac{1}{n+1},\frac 1n\right),
which is a union of open sets.
Likes sa1988
For a set not to be open there must be some point that does not have a neighbourhood within the set. In question b) you identified such a point. To show this set is not open, you must find such a point. A narrative about "discontinuities" does not suffice.
Likes sa1988
In my hand-written homework response I've written that the set is open, "... because all ##x## exist in an open interval ##\frac{1}{n+1} < x < \frac{1}{n}## "
To illustrate the set not being closed, I wrote that the complement gives all the points ##\frac{1}{n}##, all of which have no neighbourhoods.
I'm not sure if that latter sentence is good enough, however. I'm aware that my weakness is in turning 'wordy' answers into mathematical notation.
Post #4 gives one option, which is probably the best if you are allowed to assume this property of open sets. Alternatively, you have to find a neighbourhood for every ##x##, based on the intervals you have identified.
Likes sa1988
Any union of open sets is an open set by definition of a topology.
Likes sa1988
Yes, very true.
Thanks for the responses - advice noted.
And not by definition for open sets in ##\mathbb{R}^n##, in which the OP is working. In that case, it actually needs a proof. And if it's not proven, the OP cannot use it.
Forgive me if I'm mistaken but does my OP not state that we're working with the standard topology, rather than ##\mathbb{R}^n##?
If not, then I have another hurdle in this wonderful quagmire I have waded into known as set theory and topology. Ha.
Sure, but you actually need to prove that the standard topology on ##\mathbb{R}## satisfies the axioms of a topology! Once you did that, it's fine. But you can't just use the axioms without verifying them, like Orodruin wanted to do.
My biggest downfall in the whole area of mathematics is proofs. For my physics degree it's been mostly about "modelling the world with maths", but now I'm in my final year and half my courses are taught directly by the maths department. Suddenly abstract, rigorous proofs are the done thing.
I shall soldier on!
Likes PeroK
I shall soldier on!
In addition to rigorous proofs, the other difference with pure maths is that you can only assume what you have already proved. In applied maths, on any problem you can (more or less) cherry pick from all the maths you've ever learned. With pure maths you cannot, for example, assume that complex numbers exist and use their properties if you are doing real analysis.
In this case, it may be relevant what your course defines as the standard topology, where your starting point was and what you can assume you have already proved when tacking these problems.
This is another thing I'm needing to hurdle - the parts that say, "This is true because of proposition 1.34 from earlier in the notes", where the proof for that proposition is a thing I need to read about 50 times because it's in a style or language which is still quite new to me.
I guess this is where mathematicians can push out the smug banter towards physicists who don't do 'proper maths'.
Well, the standard topology is called a topology for a reason and referred to as such in the OP so I implicitly inferred from this that this has already been shown in whatever text or course the OP is following and can be assumed.
In fact, it would make no sense to refer to open sets before you have shown that they form the open sets of a topology.
That you need to show that the standard topology is actually a topology before you call it a topology should go without saying. Obviously I do understand that one has to show that a topology is a topology before using its properties and I am definitely not taking it for granted.
Related to Are the following subsets open in the standard topology?
1. What is the standard topology?
The standard topology is a type of topology used in mathematics to describe the properties of a space. It is also known as the Euclidean topology, as it is based on the properties of Euclidean space. In this topology, open sets are defined as sets that contain all of their boundary points.
2. How are subsets determined to be open in the standard topology?
In the standard topology, subsets are considered open if they contain all of their boundary points. This means that for any point in the subset, there is an open ball around that point that is also contained within the subset. This definition allows for a variety of different sets to be considered open, including intervals, circles, and more complex shapes.
3. Is the empty set considered open in the standard topology?
Yes, the empty set is considered open in the standard topology. This is because the empty set contains no boundary points, and therefore satisfies the definition of an open set. In fact, the empty set and the entire space are always considered open in the standard topology.
4. Can a subset be both open and closed in the standard topology?
Yes, a subset can be both open and closed in the standard topology. This is because the definition of an open set does not exclude the possibility of a set also being closed. In fact, in the standard topology, the entire space and the empty set are both open and closed.
5. How does the standard topology differ from other types of topology?
The standard topology differs from other types of topology in the way that it defines open sets. In the standard topology, open sets are defined as sets that contain all of their boundary points. This allows for a variety of different sets to be considered open, while in other types of topology, open sets may be defined differently, leading to different results and properties for the space.
