Are the number of electrons on both sides of the radioactive decay balanced?
In summary, the number of electrons on both sides of a radioactive decay are not balanced due to the emission of an alpha particle, which has a charge of +2. The missing electrons do not vanish but instead remain in the nucleus of the parent atom and are not captured by the alpha particle. This can be observed through the detection of positively charged radiation.
Viswanathan
For example, consider an alpha decay.
ZPAZ-2DA-4 + 2He4
For P,
Number of Neutrons = A - Z
Number of Protons = Z
Number of Electrons = Z
For D,
Number of Neutrons = [A - 4] - [Z - 2] = A - 4 - Z + 2 = A - Z - 2
Number of Protons = Z - 2
Number of Electrons = Z - 2
For He (nucleus),
Number of Neutrons = 2
Number of Protons = 2
Number of Electrons = 0
Now, the number of neutrons
on left side = A - Z
on right side = [A - Z - 2] + 2 = A - Z
the number of protons
on left side = Z
on right side = [Z - 2] + 2= Z
on left side = Z
on right side = [Z - 2] + 0 = Z - 2
It can be clearly seen that the number of electrons on both sides of an alpha decay are not balanced.
So what happened to those missing electrons?
Why do you say that the number of electrons is not balanced before and after the emission of the alpha particle?
because there are z electrons before the emission
but there are only z-2 electrons after the emission
What's to keep the alpha particle from picking up the "extra" electrons?
We know that the alpha particle comes from the nucleus of the parent atom. so the daughter must have 4 nucleons (2 protons and 2 neutrons) lesser than the parent.
but the alpha particle does not contain any electron. so the daughter must have the same number of electrons which the parent had.
so the daughter must be an negatively charged ion with 2 additional electrons. instead it is a neutral atom which may or may not be stable. how?
sorry I'm not able to understand your question
You say there's two electrons which allegedly go missing from the original element after it decays by emitting an alpha particle.
What happens to these electrons which are allegedly missing? Do they vanish into thin air? Do they move to Phoenix?
What's to keep them from being captured by the alpha particle, which has a charge of +2 when it is emitted from the nucleus of the decaying element?
I'm also asking the same question - Where did these 2 electrons go?
And if the emitted alpha particle captures these extra electrons, it must get neutralized before it comes out of the atom. So we should have detected uncharged radiations only. but we detect positvely charged radiations only. This shows that the alpha particle doesn't capture those electrons. So, where did these electrons go?
Maybe these guys can tell you:
i joined in this forum hoping that you guys might clear my doubt
Related to Are the number of electrons on both sides of the radioactive decay balanced?
1. How does radioactive decay occur?
Radioactive decay occurs when an unstable atom releases energy and particles in order to become more stable. This process can result in the formation of a new element.
2. What is the role of electrons in radioactive decay?
Electrons are negatively charged subatomic particles that are involved in the process of radioactive decay. They can be emitted during the decay process, along with other particles such as alpha or beta particles.
3. Are the number of electrons on both sides of radioactive decay balanced?
Yes, the number of electrons on both sides of radioactive decay are balanced. This is due to the principle of conservation of charge, which states that the total charge of a system must remain constant. Therefore, the number of electrons emitted during radioactive decay must be equal to the number of electrons present in the resulting atoms.
4. How do scientists measure the number of electrons in radioactive decay?
Scientists use various methods to measure the number of electrons involved in radioactive decay. One common method is through the use of radiation detectors, which can detect the emission of particles such as electrons. Other methods include spectroscopy and mass spectrometry.
5. Can the number of electrons on both sides of radioactive decay ever be unbalanced?
No, the number of electrons on both sides of radioactive decay can never be unbalanced. As mentioned before, the principle of conservation of charge ensures that the total charge of a system remains constant. Therefore, any imbalance in the number of electrons would violate this principle and is not observed in nature.
  • Atomic and Condensed Matter
