Are there a regions of space with no gravity?
In summary: If you put a heavy object on it, the sheet will bend. If you put a very heavy object on it, the sheet will bend a lot. Light rays follow paths called geodesics, and the bending of spacetime affects the way that geodesics look.In summary, the concept of space without gravity is not applicable as gravity is a property of spacetime. The expansion of the universe does not create new space, and gravity is present everywhere, even before matter existed. The recent discovery of gravitational waves does not change this understanding. The idea of "space" is relative and depends on the chosen coordinate chart. Overall, the concept of space without gravity does not make sense in the context of our
thefredman
If space can expand faster than the speed of light, then are there regions of space with no gravity?
Space news on Phys.org
Where there is mass there will be gravity regardless of the speed of light.
Isn't that counter intuitive? If space is expanding faster than mass can propagate that space then there will be no mass in that region and therefore no gravity, correct?
Or gravity is just everywhere?
Space is not expanding into some nowhere. Only the distances between masses expand. So gravitational pulls might decrease but don't vanish.
thefredman said:
... If space is expanding faster than mass can propagate ...
The space which is expanding includes matter which has mass.
That doesn't make sense though. If I have a cup full of water and then expand the cup to a liter bucket faster than the water can fill the bucket than there will be areas where water doesn't exist... even if only for a time.
Shouldn't the same apply for gravity?
The cup of water doesn't expand faster than light. Only if you compare it to another cup of water so far away that you can't even see it. (If I have understood the concept of the expanding metric correctly.)
Not sure what relativity has to do with the concept. If you simplify it down to 2 particles (a and b) that are far enough away that space is expanding faster than gravity can cause them to coalesce, will there eventually be a region between them that has no gravity whatsoever? or will it decrease to infinity?
Yes, it has been everywhere from the beginning of time. Essentially, even before matter as we know it existed, there was energy filling all that there is. And all forms of energy gravitate.
I believe the OP is infering a logical need for some kind of unfilled void into which the universe can expand. Scientists widely agree is there is no need or evidence of any 'space' outside the universe. The concept of space without gravity is a more interesting question, but, again, the answer appears to be no. For further discussion see https://einstein.stanford.edu/content/relativity/a11332.html
It isn't. This is a good example of why the "space is expanding" heuristic is misleading. The universe is filled with matter, and continues to be filled with matter as it expands, without any of the matter having to "propagate" anywhere, because there is no "new space" being created that it has to propagate into. All that changes is the average density of the matter (it decreases as the universe expands).
If you have a universe with only two particles, the cosmological models that are sometimes heuristically described as "space expanding" don't apply anyway.
If you just pick out two particles in our actual universe, with lots of other matter in it, then the two particles aren't the only sources of gravity, so the fact that they are far enough apart that each one is beyond the Hubble radius of the other is irrelevant to whether there is gravity between them.
Gravity is a property of space-time. It really doesn't make any sense to say that there are regions of space-time with no gravity. It would be something like saying there are regions of space-time with no space.
Chronos said:
I believe the OP is infering a logical need for some kind of unfilled void into which the universe can expand. Scientists widely agree is there is no need or evidence of any 'space' outside the universe. The concept of space without gravity is a more interesting question, but, again, the answer appears to be no. For further discussion see https://einstein.stanford.edu/content/relativity/a11332.html[/QUOTE
TBH, I'm not concerned with whether or not there is an unfilled void in which the universe can expand.
My question applies to the recent discovery of gravitational waves. I am more interested to know if it's possible to differentiate between space and gravity. For instance, oceanic (water) waves are created by energy; however, water can exist without the energy that creates the wave. Can space exist without gravity? or is space synonymous with gravity?
Isn't that just semantics? If you create a universe with the physical constraints of this universe wouldn't the same principles apply?
You shouldn't ask about space, because there is no such thing as "space" in any absolute sense; there is just spacetime. Splitting up spacetime into "space" and "time" requires choosing a coordinate chart, and there is no absolute meaning to coordinates.
In principle, spacetime could exist without gravity, yes, because flat Minkowski spacetime, the spacetime of SR, with no gravity present anywhere, is a possible solution of the Einstein Field Equation. However, there is also no matter or energy in this spacetime. Any spacetime with matter and energy in it will have gravity present--i.e., it will be curved, not flat; this is what the Einstein Field Equation tells us. So as long as matter and energy exist, spacetime cannot exist without gravity.
If there were only two atoms in the entire universe and 100 trillion miles away from each other, would they eventually collide?
It would depend on their initial motions. But they would affect each other gravitationally regardless of whether they eventually collided or not.
So if the space between them expanded exponentially then the effect of gravity wouldn't cease to exist; but would move toward infinity, correct?
Also, is there any proof that gravity isn't just some type of energy that exclusively moves towards to mass?
If there are only two atoms in the entire universe, the cosmological model in which "space expands" does not apply.
Also, what does "move toward infinity" mean?
What does that mean? Are you referring to some known alternate theory of gravity, or is this just your personal speculation? If it's the latter, you should be aware that personal speculations are off topic here.
No. A spacetime with only two particles in it is a different solution of the Einstein Field Equation from a spacetime with two particles plus a lot of other matter and energy. These are physically different configurations and they will exhibit physically different properties.
The force felt from each object would tend towards zero (never reaching it though) as the distance between each object increases towards infinity.
No, because that isn't how gravity is even modeled. It wouldn't even match the current accepted meanings of energy and gravity. It's like asking if there is proof that my ham sandwich isn't actually a type of mustard being expanded towards my mouth.
...a delicious expansion indeed. :biggrin:
If we assume a model in which there is no other matter or energy besides the two particles, then "space" is not "expanding"; it's just a standard Newtonian two-body approximation where the objects happen to be flying apart. So the reduction of the force between the objects has nothing whatever to do with "space expansion", even in the heuristic sense of the term; there is no such thing in this model.
If we instead assume a model in which we pick out two comoving particles in an expanding universe, I'm not sure how meaningful it is to even talk about the "force" of either one on the other; the motion of each one is affected by all of the matter and energy in the universe, and the effects do not sum linearly the way they do in Newtonian gravity. That is why I emphasized that this is a different model.
Likes Drakkith
So yes? :p
...a delicious expansion indeed.:biggrin:
Just because it does't fit within the standard model; doesn't mean it is incorrect...JS... :P
It's not that it doesn't 'fit in the standard model', it's that it doesn't even make any sense. You've just strung some words together without understanding their meaning.
thefredman said:
So yes? :p
No. I don't know what it means for the 'effect of gravity to move towards infinity'. That's why I said what I said. Remember that when we talk real, actual science, as practiced by the scientific community, accurate terminology is important. I don't expect you to use accurate terminology since it's unlikely you've ever learned it, but trying to shoehorn our answers into supporting your posts isn't going to help you or anyone else.
Please read what I said in post #19 about personal speculation. This is off topic, and if you mention it again you will receive a warning.
thefredman said:
So yes? :p
Also please bear in mind that it is not up to us to try to read your mind. It is up to you to express yourself clearly. If you don't know the standard terminology for what you are trying to discuss, it is up to you to learn it.
Yes. Einstein's GR tells us that matter deforms spacetime and we observe this deformation as gravity. The Friedmann equation is used to make toy model universes and is derived directly from GR. With this equation you can construct a universe without matter, electromagnetic radiation or dark energy. This is known as a Milne Model. However this universe will expand linearly fore ever, there is nothing that will slow the expansion or accelerate it. Matter/radiation would gravitate and slow the expansion, they do not exist in Milne but spacetime does and expands too.
This model is just Minkowski spacetime in unusual coordinates (actually just a portion of it, one "wedge" consisting of the future light cone of a chosen point). It is only "expanding" in those coordinates, and since those coordinates don't cover the entire spacetime, any physical interpretation as an "expanding universe" is strained at best.
FAQ: Are there a regions of space with no gravity?
What is gravity and how does it work?
Gravity is a fundamental force of nature that causes objects with mass to be attracted to each other. This force is most commonly observed between objects on Earth, such as the attraction between Earth and objects on its surface. Gravity is caused by the curvature of space-time, which is created by massive objects. The more massive an object is, the stronger its gravitational pull.
Are there regions of space with no gravity?
No, there are no regions of space with absolutely no gravity. Gravity is a universal force that exists everywhere in the universe. However, the strength of gravity can vary depending on the mass and distance of objects in a given region of space.
Can gravity be turned off or manipulated?
As of now, there is no known way to turn off or manipulate gravity. However, scientists are constantly studying and researching ways to better understand gravity and its effects, which may lead to the development of new technologies in the future.
How does gravity affect space and time?
Gravity affects space and time through the concept of space-time curvature. Massive objects, such as planets and stars, create a curvature in space-time, which causes objects to move towards them. This also affects the passage of time, as time moves slower in regions with stronger gravity.
Is there a limit to how strong gravity can be?
According to current scientific understanding, there is no limit to how strong gravity can be. However, there are theories that suggest that at incredibly strong gravitational forces, the laws of physics may break down. These extreme conditions are found in places such as black holes and the early universe.
